JULIET 2.0 - DREAMBOX EDITION
Linux version 2.6.9 (gcc version 3.4.4)
1.10 head.ko
Enigma cvs 20-10-2006
SmartEmu 3.0
Descriptions:
Advanced osd info with:
-Snr,Agc,Ber indications dynamic arrow and ber alert (red, orange, green)
-Frequency,Polarisation,Symbol Rate
-Dynamic label to show screen info and current date
-Display current time in the following formats HH:MM or HH:MM:SS
-Providers name
-Two menus standard and Juliet edition (active it in panel, advanced opt., expert osd)
-Picon flag (switch on and off) pictures are not included but downloadable in plugins section. blue->1->extra system setup
-New volume label (%vol) and new multicolors progress bar
-New event and snr/agc progress bar multicolors
-New Dynamic boot logo
Sept_quatre skin in height colors available for download:
-Dark and Light Blue, Green, Grey, Gold, Violin, Pink, Bronze
-Available in 16/9 and 4/3
-Full compatible with picon edition
Multiline 7 skin in height colors available for download:
-Dark and Light Blue, Green, Grey, Gold, Violin, Pink, Bronze (default)
-Available in 16/9 and 4/3 and extended and compact version
Other features:
-Inadyn service configuration
-SmartEmu 3.0 with independent start of cardservers and emu
-MediaHighwayEpg embedded you can chose the device where to save the .dat file (USB,CF,HDD) blue->1->extra system setup
-EPG data stream pop advertisment enable it from blue->1->extra OSD setup )
-Extended info (blue->3)
-PS – red key( show the list of active process)
-NetStat – yellow key (show the stat of the network connections)
-Scripts – blue key (you can run yours own scripts placed in /var/juliet/scripts)
-Internet download of plugins
-Manual install available
-Remove installed addons
-SwapFile utility (if a swapfile is already present on the desired device you can use it)
-HardDisk extra setup (Noise Level and sleeptime)
-Double main menu (Classic style menu and Juliet style menu) you can select it from blue->1->extra OSD setup)
-Sigboost included (switch on and off) blue->1->extra system setup
-Move var on removable device USB CF HDD (only for the image installed on the flash memory)
-Binding Emu, allow to bind a selected softcam to a service or a bouquet. You can set a default emu too. Active it from blue->1->extra system setup and then use the bind menu blue->2 in order to configure yours services.
-Expert web-if 5.9.7 powered by Mimi74
-Italian and english language (Others are downloadable from internet)
For those who want to use the picon addons, just download the file (available trough SmartEmu panel), then active the option from blue button, restart enigma
The position of the picon would be at the right place.
Notes:
Works on flash and multiboot for dm7000
Works on multiboot for dm7020
Disclaimer :
No key included
No softcam included
We provide this software without any warranty and we're not responsible on the use you do with.
Test in progresso
1.10 head.ko
SmartEmu 3.0
Descriptions:
-Providers name
Other features:
Notes:
Disclaimer :
No key included
No softcam included
Test in progresso
