Nuova Nemesis dm7000 1.00
Lazy1
Digital-Forum Gold Master
11 Ottobre 2003
Roma
Nemesis dm7000 1.00
Team Nemesis-Project: Gianathem, Verbatim, Mej, 3mendo, Bati®
Technical Infos:
* Enigma of: 10.05.2007 (fix Gianathem)
* Linux version 2.6.9
* GCC 3.4.4 Original CVS 1.1.0
* Web Interface: 6.0.2-Expert
* Dreambox driver v. 02-04-2007
* Busybox 1.01
* Tuxtxt v. 1.99
for use in multiboot in USB, NFS, CF or flash
Function Buttons:
* BLUE - Nemsis Panel
* BLUE > 1s - ECM INFO
* 2x BLUE - Addons
* YELLOW – Plugins
* YELLOW > 1s – EMU - CS Info
* RED - EPG list for active channel
* 2x RED - EPG style menu
* GREEN – subservices
Features:
* Nemesis EMU Manager 1.0.0
* Nemesis EMU Manager in italian & English
* Independent Start & Stop EMU / CARDSERVER
* Advanced Inadyn service configuration, with log manager
* Swap file configuration, you can set swap in USB, CF or HDD
* Setting PVR movie folder
* Move /var in USB, CF or HDD
* Advanced external programs control
* Can start / stop your own binary by panel (see /var/etc/sample_startup.sh)
* Can create your own autostart boot script (see /var/etc/sample_startup.sh)
* Support for sigboost, gSUB via advanced external programs control
* Advanced User Script
* Can run script in kernel mode
* Automount (see /var/script/mount.sh)
* Advanced System info (see /var/etc/script.xml)
* Advanced Emu info (see /var/etc/emuscript.xml)
* Advanced HardDisk setup
* Parental control shortcut
* Nemsis news
* MediaHighwayEpg
* emm, ecm support
Display Function:
* Display Snr, Agc, Ber
* Display video info
* Display frequency, polarization, symbol rate
* Display emu in use
* Display service providers name
* Display CaID, ProvID, PID
* Display Decoding Source (you can hide if you want)
* Display DC as IRDETO in OSD
* Display long date format
Addons:
* Advanced addons Manager
* Internet addons download with Proxy support
* Manual addons install
* Remove installed addons
Misc:
* Italian, English language
* Many language in download
* Extended libc
* Extended libcurl
* libfx included
No keys, No emu included
Note
Con la Nemesis potete scaricare tramite internet gli addons (legali ovviamente) messi a disposizione da Genesi-Project, per chi non fosse soddisfatto dei nostri gusti l'immagine è progettata in modo da poter inserire in var/etc un file formato unix che si chiamerà extra.url contenente il link del vostro server http personale, il formato dei file riconosciuti dalla Nemesis dovrà essere .tar.bz2 rinominati poi in .tbz2, nel menu si aggiungerà automaticamente una voce come potete vedere dalla foto sotto:
Sorgenti
Genesi-Project e il Team Nemesis-Project hanno deciso che i sorgenti di questa immagine saranno, a breve, Pubblici, l'unico vincolo (se così si può chiamare) è che gli utenti che useranno i nostri sorgenti sviluppino il loro lavoro nel nostro forum e che nelle info delle eventuali immagini da loro prodotte venga evidenziato che i sorgenti sono della nemesis, ovviamente non siete obbligati ma a noi farebbe molto piacere che si rispettassero queste 2 piccole regolette dato che nessun team fino ad ora li ha forniti, per i furbastri dato che ci sono sempre sappiate che in qualsiasi momento siamo in grado di vedere se una immagine è stata fatta usando i nostri sorgenti. Chiaramente, per ovvi motivi, non forniremo supporto per i sorgenti, se non in maniera molto limitata
Rispondi citando
salve, ho provato questa immagine è veramente ottima :) mi sono iscritto per dirvelo visto che non c'è nessun reply :)
Non sei il solo.
messa in USB, dopo la Nabilo è un IMG da considerare.
ciao
secondo me questa alla nabilio non la vede proprio sia per come è concepita sia per stabilità e video, prova a far impallare in dream oppure a cambiar canale molte volte e vedi se ti capita di sentire solo l'audio e non vedere il video come succede con le nabilio.. te lo dico io questa non perde un colpo ed è solo la 1.0, poi tra me e te ma li hai letti i nomi di chi ha fatto questa immagine ? i + giovani forse non lo sanno ma io me li ricordo quando facevano un'altro tipo sat e se sono loro non ce ne per nessuno :)
ciao
