nuovo MacroTable ToH3.x - v6.00Extended
skoca
Digital-Forum Junior Plus
21 Luglio 2004
nuovo
Macro_Table_ToH3x_v600Extended by M@X1970
che spettacolo
complimenti a tutto lo staff
file CRC: D4B97BC0
file MD5: ef5f028f4abb0a5ba60a787a3da86715
diffidate delle imitazioni
_________________________________
HumaxZone.net, 09/Nov/2006
*News:
One Touch for Favourites Section Extended (on Front Panel... without RCU)
*Features:
You can choice your preferred channel on Power On (option)
Direct access to CATone Module without crash
Time Align Module by QME5400 included...
...set current time on current service without move motor
Access to Antenna's menu directly
Info about HoT version plugged
Slide Show Mode (infinite loop; Tv/Sat to stop)
new Zapping Mode over last 3 channels (infinite loop; Tv/Sat to stop)
OnScreenDisplay Off removed
NoStop to Next/Last Favourite... greetings to Need & Majroo7 2000 (infinite loop; Tv/Sat to stop)
Other...
*ToH3.x Default Commands:
Key [Tv/Sat] Macro Mode On/Off ; Stops Macro's current execution
Keys [0+Epg] Epg Module
Keys [0+Rcl] +Cam Reset
Keys [1+Rcl] Top Black Line OSD
Keys [2..8+Rcl] Recall Last Channels
Keys [9+Rcl] Send Remote Control keys on RS232
*Utility Section:
Key [Off] Off'n'Restart from channel_xx (Optional)
Keys [0+Mute] Slide Show Mode
Keys [0+Menu] ToH Config Menu
Keys [0+Red] Parser 1177 Module
Keys [0+Green] Qme Module ToH20
Keys [0+Yellow] Search Channels Menu
Keys [0+Blue] Audio/Video personal settings... set Uhf channel value
Keys [0+White] Check time on current service and set Time Offset
Key [VPlus] Volume +5
Key [VMinus] Volume -5
Keys [0+?] Info HoT
*Favourites Section:
Keys [0+Music] Zapping Mode over last 3 channels
Keys [0+Up] Favourite=> A List Channel
Keys [0+Left] -> B
Keys [0+Right] -> C
Keys [0+Down] -> D
Key [PPlus] Skip to => Next Favourite Channel
Key [PMinus] -> Last
Keys [0+PPlus] NoStop+ => Next Favourite Channel (long flash)
Keys [0+PMinus] - -> Last
Keys [0+VPlus] Skip to -> Next "Provider List" or "Sat Orbital Position"
Keys [0+VMinus] -> Last
*Favourites Section Extended (Front Panel):
Key [Up] Skip to => Next Favourite Channel
Key [Down] -> Last
Italiano
*Novità:
Sezione Navigare tra i Preferiti Estesa (dal Pannello Frontale... senza Telecomando)
*Caratteristiche:
Puoi scegliere il tuo canale preferito alla riaccensione (opzione)
Accesso diretto al CATone Module senza blocchi
Time Align Module by QME5400 incluso...
...imposta l'ora corrente sul canale corrente senza dover muovere il motore
Accesso diretto al menu dell'Antenna
Info sulla versione HoT installata
Sezione Navigare tra i Preferiti con un tocco
Slide Show Mode (ciclo infinito; Tv/Sat per arrestare)
Zapping Mode sugli ultimi 3 canali (ciclo infinito; Tv/Sat per arrestare)
OnScreenDisplay Off rimosso
NoStop al Successivo/Precedente Preferito... ringraziamenti a Need & Majroo7 2000 (ciclo infinito; Tv/Sat per arrestare)
Altro...
*ToH3.x Comandi Predefiniti:
Tasto [Tv/Sat] Macro Mode On/Off ; Ferma l'esecuzione della Macro in corso
Tasti [0+Epg] Modulo Epg di Padawan
Tasti [0+Rcl] Reset del modulo +Cam
Tasti [1+Rcl] Linea nera in alto
Tasti [2..8+Rcl]Richiama gli ultimi... canali
Tasti [9+Rcl] Abilita l'invio del codice dei tasti via Seriale
*Sezione Utilità:
Tasto [Off] Spegni e riaccendi sul canale_xx (Opzionale)
Tasti [0+Muto] Slide Show Mode
Tasti [0+Menu] ToH Menu Config Menu...Ricomincio da 1
Tasti [0+Rosso] Parser 1177 Module
Tasti [0+Verde] Qme Module ToH20
Tasti [0+Giallo]Menu di Ricerca Canali
Tasti [0+Blu] Imposta il valore del canale Uhf
Tasti [0+Bianco]Allinea l'orario sul canale corrente
Tasto [V+] Alza il Volume di 5
Tasto [V-] Abbassa il Volume di 5
Tasti [0+?] Info HoT
*Sezione Navigare tra i Preferiti:
Tasti [0+Musica]Zapping Mode sugli ultimi 3 canali
Tasti [0+Alto] Preferiti => Lista Canali A
Tasti [0+Sin.] -> B
Tasti [0+Destra] -> C
Tasti [0+Basso] -> D
Tasto [P+] Salta al => Preferito Successivo
Tasto [P-] -> Precedente
Tasti [0+P+] NoStop+ => Preferito Successivo
Tasti [0+P-] - -> Precedente
Tasti [0+V+] Salta al -> "Provider" o "Satellite" Successivo
Tasti [0+V-] -> Precedente
*Sezione Navigare tra i Preferiti Estesa (Pannello Frontale):
Tasto [Alto] Salta al => Preferito Successivo
Tasto [Basso] -> Precedente
*YOURS Comments here:
http://www.humax-zone.net/forum/viewtopic.php?t=84
*TimeAlign_Module (hdfbin-1-190000.raw)
Set current time on current service without move motor... Many Thanks to QME5400
*MacroQmeTime_ToH3x_v600.hdf
All in one... Macro Table + Qme Module + TimeAlign Module
*Restore_Macro_ToH3x.hdf
Go back to original conditions
*WARNING : Use ONLY HDFSmart by Nostromo
to upload it to your Humax in order to avoid any possible fake!
Meglio Bruciare che spegnersi lentamente - Neil Young: "Rust Never Sleep"
Bye M@X1970 ;)
Grazie di avere riportato l'ottimo lavoro dell'ottimo M@X....:icon_wink:
E' bello vedere che esistono ancora persone che lavorano per il nostro humax:D
Do una modificata al titolo del thread poichè se non non si capisce bene:icon_wink:
