Octagon 918 HD SF
Zampetti
Digital-Forum Junior Plus
26 Gennaio 2006
Ciao a tutti, come da titolo vendo un decoder nuovo ed immacolato.Trattasi di gruppo d'acquisto dove all'ultimo si è ritirato un compratore.
La fattura è di 275 Euro Se lo volete facciamo anche 200 spedizione escluse.
Colore : Argento
mi passi un link (anche in pm) dove leggere qualche cosa su questo decoder.... ho trovato solo link in tedesco
grazie
OCTAGON SF 918 HD HDTV NEW!!!
Price: 299,00 EUR (inkl. 19% MwSt.)
-> An elegant HDTV digital satellite receiver
-> With LG tuner, 32-bit 1000 MHz processor and 400 MB of memory provides OCTAGON the HD SF 918 for a strong and first-class reception.
-> Enjoy the HD quality with less than 1 sec switching time of the programmes.
-> With the Ethernet LAN connectivity, USB, eSATA and HDMI, they have the choice of agony
-> Over the remote controlled tuner gain (AGC value) also enables the weak channels without interference to receive this receiver was unique.
-> Individual color settings (brightness, contrast, color saturation) to its Sendungsart (film, news, sports, users) allow them the best image quality.
- LINUX based !!!
Only Arte features:
- 1000 MHz - 32-bit processor
- 400 MB RAM
- 10 000 places (TV & Radio)
- Ethernet LAN - 10/100 Mbps
- E-SATA port
- USB 2.0
- HDMI connector
- VFD display (Dot Matrix Vacuum Fluorescent Display)
- 2 x CI slots for modules
- Universal CONAX Smart Card reader
Features:
- Digital Satellite Receivers MPEG 4/H.264 & DVB-S2 (DVB) compatible
- Format Resolution: 576p/720p/1080i
- 3D user-friendly OSD menu
- Clear and simple on-screen interface
- Color Adjustment: color, brightness, contrast and color saturation
- EPG (electronic program guide) for the display of program information and program preview
- 254 satellite programmable
- Level control DiSEqC 1.0, 1.1, 1.2 and 1.3 (USALS)
- LNB voltage 13/18V & 14/19V adjustable in long lines
- Video format in 4:3, 16:9 and letterbox
- Zoom & pause function
- Recall function: storing the last 20 selected stations
- Find function: stations can be found alphabetically
- Program timer function
- Sleep timer function
- 8 favourite lists for the organization of TV programmes (film, news, sports, music, children, drama, family, Misc.)
- 8 favourite lists for the organization of radio stations (film, news, sports, music, children, drama, family, Misc.)
- Parental Controls for menu and programs
- Several clear channel sorting functions such as delete, rename, move and block
- Backup & restore the setting (Backup / Restore)
- 8 buttons on the front panel
- Front buttons on / off switch
- Support for Teletext and subtitle
- Software - Updates on USB/RS-232 (PC-STB / STB STB)
- Data transfer: receiver to receiver
- Menu in 24 languages
- Games menu: Sokoban, Snake, Tetris, Mines, Slot Machine, Othello
- Calendar and calculator function
- Automatic NTSC / PAL detection
- Very fast channel search
- Multi-Search: several satellites can be marked and searched
- Manual input PID (audio, video and PCR)
- Volume difference for each channel individually adjustable
- Main background and radio background image changed
- Boat image on / off
- Div. Selectable menu animations: Stripe, spray, Slide, Fade
- Power switch on / off
- HF Modualtor
- Dolby Digital 5.1 SPDIF output (optical)
- 2 x Scart (TV / CVR)
- 2 x RCA audio output (R / L)
- 1 x RCA video output
- Component output (YUV - YPbPr)
- Dimensions: 340 x 60 x 268 mm
- Weight: about 2.5 kg
Trenutni EMU -> 02.06.2008.
Readme_Version_02-06-08_EMU_AU_V0948 for Octagon HD SF 918 HDTV :
- omissis -
QUOTE]
fin troppo esplicito, diciamo un buon decoder HD ben seguito in germania e sappiamo che là se ne intendono nel seguirlo ............. ogni giorno (e ho detto tutto "totò, peppino e la malafemmina")
Oggetto venduto ;)
Potete chiudere il post.
Ciao e grazie :D
