Il prezzo ancora non ci è stato comunicato, comunque la Oukitel dopo la fiera di Hong Kong ha inviato un comunicato stampa che mi è appena arrivato e che vi riporto integralmente. In questo momento sono di fretta e non ho il tempo di tradurlo quindi ve lo lascio in inglese, se qualcuno vuole postare la traduzione faccia pure
Right before the Global Source Mobile Electronic Show, OUKITEL announced that they will launch their new smartphone named Universe Tap on HK fair. Two days later, how is this new product? Did it succeed in standing out in the crowded show? Here is the answer.
As the world’s first fast charging fingerprint 4G smartphone, Universe Tap absolutely draw mountains of attention by its main feature. Owning a 2800 battery in 7.9mm body, Universe Tap can be charged to 50% power in 30min due to its 9V/2.5A output. If you are in a hurry to take your phone out, but don’t want to take a power bank while using, just give Universe Tap 30 min, it will save a lot of time.
Huawei Mate 7’s fingerprint press sensor has been loved since its announcement, now OUKITEL also brings the latest fingerprint-unlock technology to you. For normal fingerprint unlock like iPhone 6 and 6plus, it takes 2 steps to unlock the phone-first to light up the screen and then slide to unlock. For scratch fingerprint unlock, the accuracy is not ensured, you may need 5-6 times trying to unlock your device. For coding unlock, it’s not safe and complicated. But it just needs one step to unlock your smartphone for Universe Tap back fingerprint press sensor-fast and private.
One of the FAQs is the resolution of the smartphone. Universe Tap features the latest MT6735 chipset and more powerful quad-core 1.3GHz, available for FDD 4G network. And when we check the software, it shows Android 5.1 Lollipop!!! According to OUKITEL product manager Mr Qin, the massive production in Mid May for Universe Tap will most probably use Android 5.1. Though both called Lollipop, Android 5.1 will fix some bugs that Android 5.0 shows, making the system more fluent and smooth.
As a smartphone, even though the function is powerful, but without a wonderful look as the first attraction, few people will pay attention to it. Adopting aerospace aluminum nano-molding technology, CNC craft and metal frame, Universe Tap is definitely a feast for eyes. 5.5” HD IPS 2.5D curved screen, up to 80% screen-to-body ratio and bezel-less display, many buyers adore it so much that they are eager to order.
Camera and memory are also cared when they take a look at Universe Tap. Universe Tap is equipped with 13.0MP rear camera and a 5.0 front camera. And dual LED flash with two colors enables better and truer color reproduction than single flash. The internal memory is global top trend of 16GB ROM and 2GB RAM.
Though OUKITEL is a new brand, but it is dedicated to do each product to be the world’s first. Universe Tap is the world’s first 4G smartphone that combines fast charging and fingerprint press sensor. Together with other killing features, Universe Tap is definitely a craft of art with power and beauty combined.
