Problem Regarding Humax 5400z
gjino
15 Novembre 2006
My humax was working just fine ,and was "patched" in Humax 5400! But,the problem occured when I`ve changed system ID by accident!When realised this,I have stoped the loading process half way,I did this using Humax toolbox!After interrupting this loading process,I`ve switched on the receiver,but since then, it has never worked properly!Some times the signal level shows only 55% and some times goes to 80%,and in some cases even 0%.That means i get no picture at all,or when i do get a picture it only lasts for few seconds!I have tried the "Reset Factory",the H208 loader,the original Humax 10500 firmware and the System ID 0016.0600,but even after all this I had no luck of solving the problem!The Board is OAK II-L CPU B/D REW 4.0 ,Tuner SD1228/L MK3!Could you tell me where the problem is ,and how can I get it fixed!
Thank you very much for your help !
Hi gjino,
you got a real odd problem with your IRCI-5400
Anyway I dont think it is hopefully related to any hardware problem.
Since you state:
your proper boot loader is H2.08 and your correct sysID is 0016.0600
Please install again:
  • Humax Digital IRCI-5400 sysID 0016.0600 (menu --> IRCI-5400 --> SYS-ID Tools)
  • HIC10500-06 System ID 0016.0600 to refresh boot Loader and OTA Loader (menu --> Humax Digital --> Humax Firmw)
  • a good settings file which suites your equipment (Mono, Dual-Feed, Motor ...) (menu --> IRCI-5400 --> Settings)
To get correct files please view my Home-Page URL at my profile.
Please report here if problem is finally solved or still there.
Thank you.
I have done everything you said, but i am still getting same problem! Isthere anything else i can do to sort the problem!?
