problema con cam seca 1.05
mario_pee
9 Luglio 2003
ho un abbonamento a tv vlaanderen (belgio) in seca2 con la dragon nessun problema mentre con la aston originale non mi legge la carta.la aston mi legge altre smart card seca! sarà un problema di versione della smart card?grazie per chi mi vorrà rispondere.
Strano dovrebbe leggerla:
( Euro ) Astoncrypt
(Seca / Mediaguard)
based on the Philips 8051XA embedded CPU
( P/N : 900836 ) Ver.1.00 , flashable
( P/N : 900836 )
Ver.1.03 , flashable
( P/N : 901274 )
Ver.1.04 , non-flashable
( P/N : ) Ver.1.04r1
( P/N : 901274 )
Ver.1.05 Rev. 1.1 , non-flashable
( P/N : ) Ver.1.07
  • Common Interface
  • Seca I & II CAM
  • Software exists however to switch Ver. 1.03 to Cryptoworks and we have heard of this being converted to Nagravision too (but Nagravision has a IRD & BoxKey in protected part of flash and can't be programmed via laptop)
  • Software exists however to switch Ver. 1.05 to Conax Ver. 4.0e, Irdeto II and Viaccess RED (can't be programmed via laptop)
  • Ver. 1.03 also seems to work best for ITV Digital but it should be stressed that these CAMs aren't designed for this
  • (Ver. 6.0 ) = Seca Cards
  • (Ver. 7.0 ) = Seca II Cards
ciao:D
