Ciao,
Vorrei sapere quale e' il processo che si genera quando si attiva il DM 500 .
Al momento quando accendo il DM 500 noto questi processi :
PID Uid VmSize Stat Command
1 root 532 S init
2 root SWN [ksoftirqd/0]
3 root SW< [events/0]
4 root SW< [khelper]
5 root SW< [kblockd/0]
6 root SW [pdflush]
7 root SW [pdflush]
9 root SW< [aio/0]
8 root SW [kswapd0]
10 root SW [cifsoplockd]
11 root SW [mtdblockd]
13 root 532 S init
14 root 548 S /bin/sh /etc/init.d/rcS
22 root SW< [fe_thread]
31 root SWN [jffs2_gcd_mtd1]
46 root 604 S /sbin/inetd
57 root 544 S /bin/sh /var/bin/guru
83 root 604 S /bin/inadyn --input_file /var/etc/inadynpar.conf
86 root 596 S /bin/sattv-forumd
93 root 15168 S /bin/enigma
96 root 15168 S N /bin/enigma
97 root 15168 S /bin/enigma
113 root 15168 S N /bin/enigma
152 root 15168 S N /bin/enigma
141 root 2408 S /var/bin/CCcam_2.1.1
142 root 2408 S /var/bin/CCcam_2.1.1
143 root 2408 S /var/bin/CCcam_2.1.1
144 root 2408 S /var/bin/CCcam_2.1.1
153 root 2408 S /var/bin/CCcam_2.1.1
154 root 2408 S /var/bin/CCcam_2.1.1
155 root 2408 S /var/bin/CCcam_2.1.1
156 root 2408 S /var/bin/CCcam_2.1.1
157 root 2408 S /var/bin/CCcam_2.1.1
220 root 416 S telnetd
221 root 788 S -sh
3817 root 416 S telnetd
3818 root 700 S -sh
3934 root 340 S sleep 60
3935 root 624 R ps -elf
Gli stessi sono anche a DM500 in standby :
1 root 532 S init
6 root SW [pdflush]
7 root SW [pdflush]
9 root SW< [aio/0]
8 root SW [kswapd0]
13 root 532 S init
93 root 15172 S /bin/enigma
96 root 15172 S N /bin/enigma
97 root 15172 S /bin/enigma
113 root 15172 S N /bin/enigma
152 root 15172 S N /bin/enigma
221 root 788 S -sh
3818 root 700 S -sh
3949 root 340 S sleep 60
3954 root 624 R ps -elf
Lo stand by avviene lanciando a riga il comando :
wget hxxp://root:dreambox@127.0.0.1/cgi-bin/admin?command=standby&requester=webif -O /dev/null -q
Mentre l accensione con la stringa a riga di comando :
wget hxxp://root:dreambox@127.0.0.1/cgi-bin/admin?command=wakeup&requester=webif -0 /dev/null -q
Mia intenzione, era quello,di lanciare automaticamente questi script quando lo stesso DM500 va in stand by premendo il tasto rososo del telecomando o il tasto sull apparecchio , e mi permettesse di rinominare automaticamente il files :
/var/etc/CCcam.cfg
Avrei bisogno che lanci in spegnimento questa istruzione :
wget hxxp://root:dreambox@127.0.0.1/cgi-bin/admin?command=standby&requester=webif /dev/null | mv -f /var/etc/CCcam.cfg CCcam.cfg_old
E in accensione questo :
wget hxxp://root:dreambox@127.0.0.1/cgi-bin/admin?command=wakeup&requester=webif /dev/null | mv -f /var/etc/CCcam.cfg_old CCcam.cfg
Questi script funzionano , a riga di comando,permettendo di rinominare il files CCcam.cfg , in spegnimento inCCcam.cfg_old e in accensione , in modo contrario .
Ma quale e' il files di configurazione che legge quando si spegne e si accende ?
Mi potete aiutare?
1 root 532 S init
6 root SW [pdflush]
7 root SW [pdflush]
9 root SW< [aio/0]
8 root SW [kswapd0]
13 root 532 S init
221 root 788 S -sh
3818 root 700 S -sh
1 root 532 S init
6 root SW [pdflush]
7 root SW [pdflush]
9 root SW< [aio/0]
8 root SW [kswapd0]
13 root 532 S init
221 root 788 S -sh
3818 root 700 S -sh
/var/etc/CCcam.cfg
Mi potete aiutare?
