LNB Inverto universale 2 uscite indipendenti - 0,4db - Flangia c120
Ottimo per parabole Digiglobe
Specification (Flange c120)
Input Frequency (Ghz) ... 10.7 - 11.7 Ghz , 11.7 - 12.75
L.O Freq (GHz) ... 9.75/10.6
Polarization ...Linear
Accur.&stab. + Mhz (@25C) ... +/- 1
LNB Gain (typ.) dB ... 50~65
Gain Flatness ... 0.75dB@36MHz max, 7dB@IF p-p max
Pol. & Freq. Band control ... 13/18v 22Khz (standard)
Gain Stability ... N/A
Phase Noise ( dBc/Hz) ... @ 1 KHz - 50, @ 10 KHz - 75, @ 100 KHz - 95
Image Rejection (dBm) ... -40
Spurious ( dBc) ... -60
1db compr. Point (min., dBm) ... 0
Output Connector ... 75 ohm - "F" Female
Operating Temperature (oC) ... -30 to +60
e
Invacom QPF 031 - 0,3db - Flangia C120 - Linear & Circular polar
A 4 fully switched output CP/LP LNB with simultaneous reception of Linear & Circular polarisations
Input Frequency
FSS Band : 11.7 - 12.2 GHz & 12.2-12.7 GHz
BSS Band : 12.2 - 12.7 GHz
Output Frequency
FSS Band : 950 - 1450 MHz
BSS Band : 950 - 1450 MHz
Noise Figure : 0.3dB typical
Gain : 50 - 60dB
Interface : 18.5 mm Diameter Waveguide, C120 Flange
fatemi sapere
bye
e
Input Frequency
Output Frequency
Gain : 50 - 60dB
fatemi sapere
bye
