Sun Java JRE "reflection" APIs Sandbox Security Bypass Vulnerabilities
ERCOLINO
Membro dello Staff
Amministratore
3 Marzo 2003
Torino
Secunia Advisory: SA18760 Print Advisory
Release Date: 2006-02-08
Critical:Highly critical
Impact: System access
Where: From remote
Solution Status: Vendor Patch
Software: Sun Java JDK 1.5.x
Sun Java JRE 1.3.x
Sun Java JRE 1.4.x
Sun Java JRE 1.5.x / 5.x
Sun Java SDK 1.3.x
Sun Java SDK 1.4.x
Select a product and view a complete list of all Patched/Unpatched Secunia advisories affecting it.
Description:
Seven vulnerabilities have been reported in Sun Java JRE (Java Runtime Environment), which potentially can be exploited by malicious people to compromise a user's system.
The vulnerabilities are caused due to various unspecified errors in the "reflection" APIs. This may be exploited by a malicious, untrusted applet to read and write local files or execute local applications.
The following releases are affected by one or more of the seven vulnerabilities on Windows, Solaris, and Linux platforms:
* JDK and JRE 5.0 Update 5 and prior
* SDK and JRE 1.4.2_09 and prior
* SDK and JRE 1.3.1_16 and prior
Solution:
Update to the fixed versions.
JDK and JRE 5.0:
Update to JDK and JRE 5.0 Update 6 or later.
http://java.sun.com/j2se/1.5.0/download.jsp
SDK and JRE 1.4.x:
Update to SDK and JRE 1.4.2_10 or later.
http://java.sun.com/j2se/1.4.2/download.html
SDK and JRE 1.3.x:
Update to SDK and JRE 1.3.1_17 or later.
http://java.sun.com/j2se/1.3/download.html
Bollettino Secunia
Come Java consiglio di usare le 5.0 che sono le più recenti
