The Gemini Project 3.50 DM56x0/Triax MaxVar
Lucianopoggi
Digital-Forum Master
27 Ottobre 2003
Nuova realizzazione con Maxvar per il Team Gemini.
Attention!
This MaxVar Image is only running in flash (it has been only tested that way). Please do only use DreamUp and don´t forget the flash erase. Do not use other tools like FW or DCC.
Gemini v3.50:
Technical Infos:
* Enigma of: 06.04.2007
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.2-Expert
* Busybox 1.01
* Tuxtxt V1.99
Function Buttons:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* YELLOW - Quick-Button (can be configured via BP)
* RED - EPG list for active channel
* 2x RED - EPG style menu
* GREEN - subservices
Features:
* Own addon server via internet.
* AutoCam: Emu can be linked to channels/provider
* Cam settings: For example emu renaming, multichannel patch switchable ( >=7000 )
* OSD: EMM- and ECM- Display switchable
* Download and installation of additional features via Internet from Gemini server
* System Info: Many extra box infos (for example harddisk-temperature or all Enigma settings)
* Gemini news loaded in background
* JPEGs can be rotated and the EXIF tags can be displayed ( >=7000 )
* Support for OGG/Vorbis
* Random function for MP3 and OGG
* Quick-Button-Menu: Many extra features for the yellow button
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB (>=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted harddisk (only working without internal hard drive, mountpoint set to "var/mnt/hdd" and at least 3GB disk space)
* Extra menu: Settings for many features like Inadyn, HTTPD, EPG-Cache, "/var" swap-out and many more
* Backup function
* Dreamnetcast: inclusive Shoutcast TOP(100)
* Background pictures for Radio, MP3 and SCAN can be changed via Bluepanel
* Own scripts can be started via Blue Panel
* Calender including reminder (can be changed via .../calendar.conf)
* MVI's can be converted and tested (from JPG, BMP, GIF or PNG)
* Bootlogo for 7020 can be changed via menu
* New font and libfribidi for arabic language
* EPG for Dishnetwork
* 2 new root entries for music and pictures can be created in the filemenu (BP->Extras/Settings->Root-Entry)
* Create your own Satellites.xml
* Dreambox can be used as printserver (BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Alarm clock with volume offset adjustable playing your own WAV-files.
* Display of current channel stream rates ( >=7000)
* cifs-1.42b
* Multisocket second camd socket (cam1.socket) switchable.
* Register an own addon server( useraddon.xml)
* Provider, Frequencies, kSyms, and FEC could be displayed on the Infobar (If the Skins matches this function)
* Picon implemented in Gemini
* "real" automount, for examples have a look at: /var/etc/automount.conf. Devices, NFS or CIFS will be automatically mounted (Editor within the BP-Menu)
* Dropbear is activ in all Images (SSH - Deamon)
* cifs-1.44
* Extensions for Skins (Thumbnails, 3D-Font, Pictures for Progressbar displaying)
* Backgroundpictures (Radio- and File Mode) could be displayed as a Screensaver. Fileformat is the same as the @bexbier Screensaverplugin format
* Backgroundpicture can be switched off (Plasma-Fix)
* Dreamnetcast with Streamripper (direct recording from the server and automatic conversion into mp3 File format
* Upnp Client and Server (available for DM500 - DM7000 as a Addon from our Server)
* The Position of the Infobar can be changed without editing the Skinfile
* Dropbear are now switchable (DM500 - DM7000: Standard->off)
New:
* fuse update from 2.6.1 up to 2.6.3
* libupnp update from 1.4.1 up to 1.4.3
* ushare update from 0.9.8 up to 0.9.10
* streamripper update from 1.61.3 up to 1.61.27
Fix & Update:
* see CVS
* upnp
IMPORTANT:
* The ever last Gemini Image for Dreambox Models: DM56x0
Special Characters will be displayed now
Full ts support from upnp Server
Interfaces WebIF:
http://127.0.0.1/cgi-bin/GeminiInfo
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = number of cam)
http://127.0.0.1/cgi-bin/InitCam
http://127.0.0.1/cgi-bin/ResetCam
We'd like to thank everybody who paricipated in the "Gemini suggestion" thread. Unfortunatly many things can not be realized from our side.
This images doesn't contain any keys or softcams. Backups or other modified Images are not from us and won't be supported!
Recommendation:
If you don't install the Image in flash memory, the flash image shouldn't be of a old version. A swap file/partition (>= 16MB) should be present
if several processes running in background.
Download via Database
Thanks a lot and have fun
Your Gemini-Team
