The Gemini2 Project 2.20 DM7025
humaxiano
2 Giugno 2002
Roma
Gemini2 v2.20:
Technical Infos:
* Engima from: 13.02.07
* GCC 4.1.0 Original CVS
* Busybox 1.2.2
* Kernel 2.6.12.6
Function Buttons:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* RED - Record
* GREEN - Subservices
Features:
* Own Addon-Server via internet
* Downloading and installation of additional features via internet from Gemini server
* EMM- und ECM- Display switchable
* Behaviour of infobar can be changed via Menu
* System Info: Many extra box infos (for example harddisk-temperature, storage usage, mountpoints)
* Extra Menu: Settings to many extras like Inadyn, HTTPD, NFS-Server, calendar
* Own Scripts can be started via Blue Panel
* Calendar including reminder (can be changed via /etc/calendar.xml)
* Dreambox can be used as printserver
* Kernel modules can be reload separately
* Create your own Satellites.xml
* Support for CDROM/DVD, no matter if IDE or USB port
* Display of current channel stream rates
* SWAP setup and start automatically
* HDPARM values for harddisk can be changed via menu
* Storage location of epg.dat can be changed via menu
* Display of CaIDs via Infobar
* Password can be changed via menu
* Autocamd
* camd scricpt can be edited
* HDD performance
* Weather Plugin with 10 days forecast
* RSS/RDF reader with TOP list from RSS-scout
* Active PiP
* Blue Button with following functions: 1 x (short) Blue Panel, 2 x (short) Blue Panel -> Extras/Settings, 1 x (long) blue PiP
* The image does now contain a useraddon.xml in /etc to enter an own addon server which will additionally be displayed in download menu. The file actually contains a example.
* Nemesis skins
* Installation of addons via browser
* IPK can be choosen and installed via browser
* Installation of plugins without Enigma restart
* Picon integrated in Gemini (the PNG file must have the same name as the channel) -> Installation of Pic-Icons via Blue Panel
* True automount, examples in /etc/automount.conf. Devices, NFS or CIFS get mounted automatically and also erased if they are not in use for longer than 2 minutes (only working if the kernel of Gemini 1.8 is in use, config via Blue Panel)
* Dreamnetcast
* PictureViewer from CVS
* Webcam
* real flashing clock when recording in standby
New:
* Dreamnetcast and Streamripper (direct recording from server and coding into mp3´s)
* Webcam-Viewer extended (FullScreen mode - settings will be saved)
* EPG Refresh
* Upnp Server / Client
* Dropbear (ssh) can now be tourned on/off
Fix + Updates:
* Automount Editor
* Stream-Traffic
* see CVS
Mi assento mezza giornata e guarda che mi arriva sta bella news!! :D :D
Grazie humaxiano ;)
