<satellites>
... omissis
<sat name="80.0E Express-80" flags="1" position="800">
<transponder frequency="10981000" symbol_rate="44948000" polarization="1" fec_inner="2" system="0" modulation="1" />
<transponder frequency="11044000" symbol_rate="45000000" polarization="1" fec_inner="8" system="1" modulation="1" />
<transponder frequency="11106000" symbol_rate="45000000" polarization="0" fec_inner="8" system="1" modulation="1" />
<transponder frequency="11106000" symbol_rate="45000000" polarization="1" fec_inner="8" system="1" modulation="1" />
<transponder frequency="11169000" symbol_rate="35007000" polarization="1" fec_inner="3" system="1" modulation="2" />
<transponder frequency="11481000" symbol_rate="45000000" polarization="0" fec_inner="8" system="1" modulation="1" />
<transponder frequency="11481000" symbol_rate="45000000" polarization="1" fec_inner="8" system="1" modulation="1" />
<transponder frequency="11544000" symbol_rate="45000000" polarization="0" fec_inner="8" system="1" modulation="1" />
<transponder frequency="11544000" symbol_rate="45000000" polarization="1" fec_inner="2" system="0" modulation="1" />
<transponder frequency="11606000" symbol_rate="45000000" polarization="0" fec_inner="8" system="1" modulation="1" />
<transponder frequency="11606000" symbol_rate="45000000" polarization="1" fec_inner="8" system="1" modulation="1" />
<transponder frequency="12525000" symbol_rate="30000000" polarization="0" fec_inner="2" system="1" modulation="1" />
<transponder frequency="12601000" symbol_rate="30000000" polarization="0" fec_inner="1" system="0" modulation="1" />
<transponder frequency="12688000" symbol_rate="45000000" polarization="0" fec_inner="7" system="1" modulation="1" />
</sat>
... omissis
</satellites>
Ma alla fine hai catturato le frequenze dell'80 est?grazie,ma quelli li ho già inseriti,mi mancano i canali sul setting
Secondo me dovresti andare su blindscan (o ricerca automatica) che dovrebbe apparire l'80 est.no,se non ho i canali sul setting come faccio a fare il puntamento
#NAME [80.0 E] ===== Express-80 =====
#SERVICE 1:0:1:C9:66:1:3200000:0:0:0:
#SERVICE 1:0:1:CA:66:1:3200000:0:0:0:
#SERVICE 1:0:1:CB:66:1:3200000:0:0:0:
#SERVICE 1:0:1:CC:66:1:3200000:0:0:0:
#SERVICE 1:0:1:CD:66:1:3200000:0:0:0:
#SERVICE 1:0:1:CE:66:1:3200000:0:0:0:
#SERVICE 1:0:1:CF:66:1:3200000:0:0:0:
#SERVICE 1:0:1:D0:66:1:3200000:0:0:0:
#SERVICE 1:0:1:D1:66:1:3200000:0:0:0:
#SERVICE 1:0:1:D2:66:1:3200000:0:0:0:
#SERVICE 1:0:1:D3:66:1:3200000:0:0:0:
#SERVICE 1:0:1:D4:66:1:3200000:0:0:0:
#SERVICE 1:0:1:D5:66:1:3200000:0:0:0:
#SERVICE 1:0:1:D6:66:1:3200000:0:0:0:
#SERVICE 1:0:1:D7:66:1:3200000:0:0:0:
#SERVICE 1:0:1:D8:66:1:3200000:0:0:0:
#SERVICE 1:0:1:D9:66:1:3200000:0:0:0:
#SERVICE 1:0:1:DA:66:1:3200000:0:0:0:
#SERVICE 1:0:1:DB:66:1:3200000:0:0:0:
#SERVICE 1:0:1:DC:66:1:3200000:0:0:0:
#SERVICE 1:0:1:DD:66:1:3200000:0:0:0:
12688 hgrazie,hai la scansione della ferequenza 12688 Н 45000?
#SERVICE 1:0:1:66:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:67:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:68:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:69:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:6A:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:6B:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:6C:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:6D:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:6E:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:78:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:D0:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:D1:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:D9:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:DA:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:DB:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:395:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:396:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:3BA:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:3C3:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:3C8:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:3C9:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:3CF:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:3D0:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:3D1:12F:1:3200000:0:0:0:
#SERVICE 1:0:1:3D2:12F:1:3200000:0:0:0:
#NAME ---------- EXPRESS 80.0°E ----------
... omissis
... omissis
#NAME User - Bouquets (TV)
... omissis
#SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.dbe179.tv" ORDER BY bouquet
eDVB services /4/
transponders
...omissis
03200000:012f:0001
s 12688000:45000000:0:7:800:2:0:1:1:0:2
end
services
...omissis
0068:03200000:012f:0001:1:0
Матч ТВ
p:Orion Express,C:0000
end
I boquet dei vari TP degli 80E (vedi sopra) vanno inseriti in un file userbouquet.xxxxx.tv
es. userbouquet.dbe179.tv
Codice:#NAME ---------- EXPRESS 80.0°E ---------- ... omissis #SERVICE 1:0:1:66:12F:1:3200000:0:0:0: #SERVICE 1:0:1:67:12F:1:3200000:0:0:0: #SERVICE 1:0:1:68:12F:1:3200000:0:0:0: #SERVICE 1:0:1:69:12F:1:3200000:0:0:0: ... omissis
poi va' aggiunto il riferimento al file creato nel file bouquets.tv
Codice:#NAME User - Bouquets (TV) ... omissis #SERVICE 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.dbe179.tv" ORDER BY bouquet
i canali ed i transponder sono contenuti nel file lamedb
Codice:eDVB services /4/ transponders ...omissis 03200000:012f:0001 s 12688000:45000000:0:7:800:2:0:1:1:0:2 / end services ...omissis 0068:03200000:012f:0001:1:0 Матч ТВ p:Orion Express,C:0000 end
oltre a modificare il file satellite,xml per aggiungere il sat e le frequenze
ma se non sai come si procede manualmente meglio lasciar perdere
usa un editor tipo DreamSet....
oppure punta i 70.5E e poi dopo aver modificato l'elevazione per gli 80E procedi per tentativi spostandoti di circa 10° cercando i canali
oppure procurati uno strumento adatto![]()
In che senso?ho provato ma non cè lo fatta a puntarla
