diablo cam
always
16 Giugno 2003
Lugano? No Lucano.
New Diablo cam
Ho letto agli "inferi" questa novita', e riporto un po' il tutto.
Se qualcuno sa info in merito faccia sapere....
Dablo Cam.
The Cam Stand Alone will do the following functions:
Communicates with the Base via Wireless. Reads all the Smartcard in the 2 smartcard readers. All CAS Systems are supported. Officially Conax Cas 5 will be supported Irdeto 1 and 2, Seca 1 and 2, Viaccess 1 and 2, Conax, Cryptoworks, DreamCrypt, and some more he he... ;)
Supports all the Emulators actually around. A PC tool will allow you to convert existing typical softcam.key files into Diablo format and then trasfer the new softcam.key directly to the CAM without the need of re-programming the CAM all in wireless mode. Simply Drag and Drop.
Emulators: Irdeto 1, Seca 1 and Seca 2 (with twister), Nagra 1 and 2 and some exclusives coming…
File System. Once it is connected to the Base it will be possible to see the Cam content through a File system like a USB pen by specific software.
Smartcard logger function. It will log all the Smartcard traffic between Cam and Card. This function is very very helpful to log all the traffic. ** to be implemented **
Transport Stream logging. It will log some transport stream packets and send them via Wireless to the Base. Log files can be retreived via Wireless. ** to be implemented **
Smartcard Check. The Cam will check and give information about all the Smartcard inserted in the Cam or in the Base.
Multilanguage menu. All main languages will be supported. Most of the common languages are supported by the XML menu.
DVB Info. All DVB-Info will be shown on the screen. PID, CAID etc etc.
Sends/Receives Messages from the Base. This function allows the Cam to receive text messages from the Base and showing those on the OSD screen in real time.
Marriage with the Base. The Cam must be married with a Base to be able to make it working. One “System Administrator” will be chosen in order to set system’s privileges i.e. Parental Controls etc etc.
Administrator Menu. The Administrator will be able to set all the other users privileges of viewing.
Pin protected functions. Throught this menu you will access to some specific fucntions of the CAM that can be restricted to the normal user.
Fully customizable XML menus. All menus can be dragged and dropped with customized by language or funcions menu.
Fully Firmware Upgradable. It can be upgraded by Fun Card, Cas Interface or Base equipment.
Wireless splitter functions. This function allows the sharing wireless of one card inserted in the Base. All privileges for sharing (allowed channels etc etc) are decided by the Administrator Menu.
Transport Stream Delayer function. Thanks to the Delayer all the Transport Stream can be delayed up to 2,6 seconds. Experts will understand what this means…
Base.
The Base can be working Stand-Alone or connected to a PC.
Stand-Alone functions (NOT CONNECTED TO A PC):
Multiple Smartcard Reader. Reads up to 2 cards in standard version but can read up to 6 cards in advanced version. The Smartcard will be shared between one or more than one card.
“Marriages” a Cam and can work the “Divorce”. Simply pressing a button on the CAM it will associate the base to the CAM and the way around to “dis-associate” it.
Splitter function. Shares the 2 Smartcards with the “Married” Cams.
PC Connected functions (CONNECTED VIA USB 1.1 OR 2.0):
Cam Programming. Can program different firmwares into the Cam and you can browse the CAM content of the Dataflash.
Send Multimedia messages. Can send Multimedia messages to the Cam.
Special Maintenance Software.
Browse Cam content (like above with a File System) and send/remove files from the Cam like an Hard-Drive. The user will be able extract .log files generated by logging functions (Smartcard or Transport Stream)
Cam programming will allow the user to change the firmware.
Allow the user to set the various “Marriages” and “Divorces”.
CardSharing?? You have been told...
ancora pero' non si riesce a capire se supporta la card nostrana, si hanno notizie ufficiali e definitive?
adesso di questa cam si sanno anche i prezzi è un prodotto du**bs
tutto nel relativo sito ciao...
domanda
Salve e scusate se mi intrometto nella vostra discussione siccome vorrei sapere qualcosa anche io su questa cam mi sapete dire dove posso reperire le prestazioni.
Grazie e buon lavoro
Puoi trovare qualche notizia nel negozio on line della casa produttrice anche del cas, la famosa duolabs... :eusa_whistle:
poco chiaro
DiabloCam è la prima CAM Wireless con standard Zig-Bee (IEEE 802.15.4).
La CAM possiede uno SLOT per l'inserimento di una Smartcard formato Plug-In (come una SIM GSM).
La CAM si collega alla Base (non inclusa) che offre la possibilità di inviare messaggi multimediali attraverso il PC direttamente verso il vostro TV.
non si usa più il cas?
ma non mi convince:
La CAM è compatibile con la Smartcard associata. (quale...)
prezzo indicativo senza iva cam + base 150 euro (caruccia)
Se avete informazioni più dettagliate xchè dal sito non mi sembra che diano istruzioni molto chiare, grazie
basilico ha scritto:
Ragazzi, dovrei potrei reperire info un po piu' precise...
mi sa che al momento le sole info sono quelle presenti sul sito ufficiale del produttore.
Per avere risposte alle varie domande (tra cui la compatibilta' con la scheda italiana) bisogna attendere che arrivi sul mercato e che qualche "Ginny pig" ci faccia sapere.
