Discussione su AdwCleaner
  • Creatore Discussione Creatore Discussione Ospite
nuova versione => 7.2.0
New Features
Ability to download & install Malwarebytes 3 with one click
List existing logfiles at the end of reports
Add Help icons in Settings that link to explanations
Changes
Slightly update UI to follow Malwarebytes 3.5 look
Improve Firefox scan & clean modules
Improve Chrome scan & clean modules
Update translations
Update internal components
Definitions 2018.06.1.2
Bugfixes
Ability to open logfiles with double-click
Various UI improvements
Crash while scanning Firefox preferences
Fix false positives
Improve MyWebSearch and other Generics detections
v7.2.1 [26/06/2018]
a) New Features
Ability to save the current window size and restore it on the next launch
AdwCleaner will now use a settings file in the same folder than AdwCleaner.exe so that it can be shared accross network shares or USB keys,
Add a debug log output when activated from the settings
Please tell us how would you recommend AdwCleaner to others with the new window asking for your opinion
AdwCleaner is now aware when MBES client is present
b) Changes
Keep checked state of quarantine elements between switched tabs
Improve DownloadProtect detections
c) Bugfixes
Support translations for on/off in Settings
Generic detections fixes and updates
Memory leaks
Various UI issues
Database to 2018.06.19.1
https://toolslib.net/downloads/viewdownload/1-adwcleaner/history/
La nuova versione del programma me l'ha proposta solo facendo Scansiona ora, non è partita la scansione ma l'avviso di scaricare la nuova versione.
Dando l'ok, ha provveduto a scaricare l'ultima versione nella mia cartella abituale Download. Mi pare che in passato quando avvisava di un nuovo aggiornamento, bisognava andarlo a cercare e scaricare dal loro sito, mentre adesso ha fatto il download in automatico.
esatto, prima solo dal sito si scaricava ;)
ed era proprio strano prima....ti avvisava ma non ti dava l'ok per scaricare
AdwCleaner v7.2.2 (16/07/18)
Disponibile AdwCleaner 7.2.2
v7.2.2 [16/07/2018]
New Features
Ability to add an element or a family to exclusions directly from the scan results contextual menu
Ability to open the Malwarebytes Threat center directly from the scan results contextual menu
Changes
The UI is now available in en_UK in addition to en_US.
Support for Traditional Chinese in addition to Chinese Simplified
Improve URLs detection
Update HSTS policy expiration
Bugfixes
Improve the removal of all AdwCleaner files when uninstalling
Update Generic detections
Fix DriverPack detection
Improve Startup detection module
Fix Crash when closing processes [7.2.1 hotfix]
Definitions 2018.07.12.1
v7.2.3 [30/08/2018]
a) New Features
- The left sidebar is not disabled anymore during critical processes.
- Improved Windows 7+ integration: the progress is now displayed in the taskbar with a specific color dep ending on the number of elements detected.
- Improved remediation capabilities.
- Prepare major database optimization in upcoming versions (size reduction, detection improvement, ...).
b) Changes
- Update Malwarebytes moto: "Imagine a world without malware. We do.".
- Display the database status in the logfile header: "Cloud" / "Local".
c) Bugfixes
- Do not detect vaccines anymore.
- Update Generic detections
- Definitions 2018.08.30.1
Versione 7.2.4.0
New Features
Automatic updater: it's no longer needed to manually download a new version of AdwCleaner.
Changes
Logs and Quarantine tables are now sorted by date, and not by text.
Bugfixes
Fix a crash when the basic repairs are run without prior detections
New generic detections
Fix detection of vaccines
Fix the upgrade process for build increments
Update translations
Definitions 2018.09.21.1
Ci lavoravano da parecchio, vedere le tante beta precedenti a questa
v7.2.5 [16/11/2018]
New Features:
Submit False Positives directly from the result scan contextual menu.
Changes:
Update Qt to 5.9.7
Definitions 2018.11.14.1
Bugfixes:
Fix Crash during Firefox scan
Do not display the update prompt on top of the EULA
Make quarantine more reliable
Update generic detections
Fino a stanotte era ancora una beta, ci lavoravano da parecchi giorni...
