Discussione su Malwarebytes
Disponibile Malwarebytes 5.2.10.182 (component package 130.0.5212)
You can get the update right away by clicking "Check for updates" in Settings > General. Or, it will be automatically installed if you have automatic updates enabled.
Features and improvements
Added two new Trusted Advisor recommendations:
A reminder for Identity Theft Protection customers to activate their subscription
A prompt encouraging new users to try our free Digital Footprint Scan
Issues fixed
Fixed an issue that disabled Web Protection after downgrading from latest beta version to latest production version
Resolved incorrect notification positioning in case of screen DPI or resolution changes
Additional notes
This release also includes all features and fixes originally introduced in v5.2.9.176 (component package 129.0.5196). That version's rollout was paused due to the Web Protection issue, which has now been resolved.
Malwarebytes 5.2.11.183 (17/04/25)
Disponibile Malwarebytes 5.2.11.183 (component package 131.0.5227)
  • Added location info in VPN connection notification
  • Introduced a new setting to disable the “What’s New” notification
  • Refined Dashboard layout for free users
Issues fixed
  • Fixed an issue where the first VPN connection rule added was not persisted and was lost after restarting the product
  • Fixed minor localization issues
Malwarebytes 5.3.0.186 (01/05/25)
Disponibile Malwarebytes 5.3.0.186 (component package 132.0.5253)
  • Introduced a new Tray Menu with a modern design, quick-access shortcuts, and simplified navigation
  • Integrated “Scan with Malwarebytes” into the modern Windows 11 right-click context menu
  • Redesigned the Identity page for better clarity and ease of use
  • Added a discreet animation to the active Real-Time Protection card on the Dashboard
  • Enhanced the Dashboard experience for Teams users, who can now more easily add new devices to their subscription
  • Added advanced settings to customize Brute Force Protection configuration
  • Refreshed the Title Bar design to improve visual consistency and usability
Issues fixed
  • Fixed a crash caused by adding a trailing forward slash in duplicate allow list URLs
  • Resolved a bug where Trusted Advisor UI broke after a trial ended without a scan ever being run
  • Fixed an issue where the Browser Guard integration sometimes generated orphaned MbamBgNativeMsg.exe processes
Disponibile Malwarebytes 5.3.1.188 (Component Package 133.0.5274)
Features and improvements​
  • Added Windows Tools dashboard to give customers on Windows 11 the ability to improve their security and optimize their devices.
    • Added the Startup Applications tool to view and manage apps that launch at startup.
    • Added the System Tweaks tool to repair common issues, adjust privacy settings, optimize performance, and customize your Windows device.
    • For more information, see Windows Tools in Desktop Security.
Issues fixed​
  • Resolved an issue where a Trusted Advisor alert specifically for Windows 11 did not appear on some Windows 11 devices.
  • Fixed minor usability and localization issues.
Disponibile Malwarebytes 5.3.2.195 (Component Package 134.0.5279)
Improved dashboard usability and localization.
Improved the display behavior of VPN connected/disconnected notifications.
Issues fixed
Fixed an issue where the tray menu would appear on the wrong monitor in multi-display setups.
Fixed a bug that prevented device deactivation for some users.
Fixed an issue where Ransomware Protection would sometimes not shut down properly, causing delays on Windows shutdown.
Disponibile Malwarebytes 5.3.2.195 (Component Package 134.1.5283)
Issues fixed
  • Fixed an issue that prevented Exploit Protection from working on some Windows 7 and Windows 8 machines
  • Resolved an issue that was causing the mbambgnativemsg.exe (native message host) process to crash on some devices
Malwarebytes 5.3.3.198 (24/06/25)
Disponibile Malwarebytes 5.3.3.198 (component package 135.0.5296)
  • Brand new Malwarebytes-managed VPN backend
  • Restructured Notifications Settings page and introduced more granular controls
  • Slightly revisited onboarding experience for new installations
  • Refined Dashboard layout for free and licensed users
  • Improved SSO activation flow for a smoother login experience
  • Aligned Dashboard and Tray Menu behavior for VPN connect/disconnect actions
  • Enhanced proxy settings validation to prevent misconfigurations
Issues fixed
  • Fixed an issue where Exploit Protection failed to load on some Windows 7 and Windows 8 machines
  • Resolved a crash when using the new Tray Menu with Tamper Protection enabled
  • Other minor usability improvements across the interface
Disponibile Malwarebytes 5.3.4.202 (component package 136.0.5312
  • Improved the experience for providing in-app feedback by adding a way to submit feedback from the account profile menu without a forum account.
  • Minor usability improvements across the app interface
Issues fixed
  • Fixed an issue with tray menu positioning on some multi-monitor setups.
  • Miscellaneous bug fixes.
Disponibile Malwarebytes 5.3.5.204 (component package 137.0.5331)
  • Re-introduced Deep Scan, a new Advanced Scan type recommended after blocking or removing threats
  • Added new Windows Firewall Control feature preview to the Tools, feel free to try it and provide your feedback
  • Revisited Dashboard layout for free version
Issues fixed
  • Minor usability issues
Issues fixed
Issues fixed​
  • Fixed some minor usability issues.
Disponibile Malwarebytes 5.3.5.205 (component package 138.0.5346)
  • Improved the onboarding experience with minor usability enhancements.
  • Updated My subscription page design for better clarity.
  • Added text explaining Scan notifications settings in Notifications page.
  • Updated firewall filtering profile colors in Windows Firewall Control feature for Windows 11 users.
Issues fixed​
  • Fixed minor UI issues with Windows Firewall Control feature for Windows 11 users.
  • Fixed various localization and usability glitches.
Disponibile Malwarebytes 5.3.7.209 (Component package 139.0.5357)
  • Refreshed the side bar and title bar layout for a smoother and more streamlined experience.
  • Tools:
    • Windows Firewall Control and Startup Applications are now available for Windows 10 users.
    • Access to Tools can now be locked behind a password using Tamper Protection.
  • Removed Trusted Advisor recommendation for Chrome updates.
Issues fixed​
  • Fixed minor bugs, usability, and localization issues.
  • Tools:
Issues fixed​
Lo usate ancora come alternativa "manuale", per controllare ogni tanto?
Malwarebytes 5.3.8.212 (04/09/25)
Disponibile Malwarebytes 5.3.8.212 (component package 140.0.5364)
  • It is now easier to add previously-blocked websites to the Allow List - directly from Detection History!
  • Minor localization and usability improvements
Issues fixed
  • Resolved an issue where scanning from the Windows 11 context menu didn’t always process all selected files.
  • Fixed an issue where keyboard navigation wasn’t working properly in Advanced Scan options.
Disponibile Malwarebytes 5.4.0.213 (component package 141.0.5376)
  • Added a new interactive guide on the Dashboard, designed to help users discover the full range of Malwarebytes features.
  • Scheduled Scans can now be named, making it easier to organize and tell them apart.
Issues Fixed
  • Fixed a crash that could occur when creating a duplicate Allow List entry.
  • Resolved an issue where multiple tray icons could appear in certain cases.
  • The VPN notification toggle is now available for Privacy-only licenses.
Disponibile Malwarebytes 5.4.1.215 (component package 142.0.5389)
  • Introduced a Privacy Controls feature that helps you optimize your privacy by turning off Windows settings that track your activity or allow ads". For more information on Privacy Controls, see this article.
  • Updated the Website Blocked notification with clearer text and a more streamlined way to add websites directly to the Allow list.
  • On the main dashboard, refined the VPN card text for better clarity and user understanding.
Issues fixed​
  • Fixed an issue that prevented Anti-Ransomware Protection from starting on certain Lenovo devices.
  • Fixed a bug causing the tray menu to display incorrectly when the VPN Kill switch was turned on.
  • Added missing auto-fill functionality for IP addresses when adding a website to the Allow list.
  • Fixed a bug where the "If scan missed or skipped" field would disappear in scheduled scans settings.
  • Miscellaneous in-app text, localization, and accessibility improvements.
Disponibile Malwarebytes 5.4.1.217 (component package 143.0.5487)
  • Added two new toggles to Privacy Controls for Windows 11 users:
  • Manage ads in Windows notifications.
  • Manage personalized content in Windows Settings.
  • Introduced the ability to create a backup of the Allow list and restore older lists directly from the Allow list tab.
  • Added quick access to the Scan Scheduler from the Scanner card’s three-dots menu.
  • Minor UI and localization improvements.
Issues fixed​
  • Fixed an issue that caused multiple Malwarebytes icons to appear in the system tray.
  • Fixed an issue that prevented the installer from finishing installation on some devices
Disponibile Malwarebytes 5.4.3.221 (component package 144.0.5414)
  • Added the ability to detect Remote Desktop software installed on your Windows device. From the Privacy Controls page, view detected software and choose whether to keep or remove it. Learn more about the Remote Desktop Monitoring feature here:
  • Suggestion banners that appear on the main Dashboard now include a suggestion to schedule a scan with the Scan Scheduler feature.
  • Improved the Allow list to automatically scroll to the most recently added item for added convenience.
Issues fixed​
  • Fixed an issue where Web Protection blocks sometimes ignored and blocked items that were already added to the Allow list.
  • Minor UI and localization fixes.
