Discussione su Video LAN VLC
@BOBBYS che ne pensi della nightly-win64-llvm non mi consigli di tenerla? Versione 4.0.0 ultima release 0459 stamani
Se già la utilizzi e la ritieni stabile, sebbene sia ancora in sviluppo, continua con la v4.0.0
Altrimenti se cerchi la stabilità (si spera) vai con la prossima v3.0.22
VLC 3.0.22
In arrivo VLC 3.0.22 ... :)
Disponibile la prima RC, probabile la release finale sara' disponibile dopo gli ultimi test.
Rilasciata la seconda RC
Fra poco la release finale ?
"La versione 3.0.22 diventa la versione di VLC con il maggior numero di correzioni di sicurezza di sempre!"
Codice:
Changes between 3.0.21 and 3.0.22-rc2:
Core:
 * Assume subpictures are in SDR by default
Windows:
 * Add Windows ARM64 builds (Minimum Windows 10 RS5 17763 / 1809)
 * Fix support for Windows XP SP3
 * Allow renaming/moving/deleting of playing file on Windows
 * Restrict SystemParametersInfo calls to Windows XP
Decoders:
 * Fix Opus channel mapping
 * Fix hardware decoding with VideoToolbox of XVID MPEG-4 video
 * Add dav1d-all-layers option
 * Fix DVD CEA-608 captions parsing
 * Fix ProRes 4:4:4:4
 * Disable decoding using libdca, libmpeg2 and liba52 by default in favor of libavcodec
Demuxers:
 * Add support for DMX audio music (MUS) files
 * Handle mkv-use-chapter-codec option
 * Add A_ATRAC/AT1 support in matroska
 * Prevent FLAC seeking logic get stuck
 * Handle pictures in FLAC
 * Fix VOB/AOB LPCM/MLP detection failing occasionally
 * Cut QNap title on first invalid character
 * Fix display of certain JPEG files
 * Fix playback of very short ASF files (duration less than 1s)
 * Multiple fixes in MPEG-TS
 * Fix crashes in multiple demuxers (reported by rub.de, oss-fuzz and others)
Input:
 * Fix SFTP seeking for large files on 32-bit OS
Interface:
 * Add option to use dark palette (Qt)
 * Add compilation support for newer versions of Qt5
 * Qt: Fix scrolling on volume slider
Service Discovery:
 * UPnP: remove SAT>IP channel list fallback
Video Output:
 * Use a better stretch mode in wingdi
 * Fetch missing device information when running in UWP
Video Filter:
 * Add AMD GPU Frame Rate Doubler (Direct3D11)
 * Improve visualization of low frequencies in spectrogram
Contrib:
 * Update amf to 1.4.34
 * Update dav1d to 1.5.1
 * Update FFmpeg to 4.4.5
 * Update freetype to 2.13.1
 * Update gettext to 0.22.5
 * Update gcrypt to 1.10.1
 * Update glew to 2.1.0
 * Update gmp to 6.3.0
 * Udpate gnutls to 3.8.10
 * Update harfbuzz to 11.5.0
 * Update iconv to 1.17
 * Update libarchive to 3.8.0 including support for RAR 5.0
 * Update libass to 0.17.3
 * Update libbluray to 1.4.0
 * Update libmatroska to 1.7.0
 * Update libogg to 1.3.6
 * Update libpng to 1.6.50
 * Update libvpx to 1.15.2
 * Update lua to 5.1.5
 * Update openjpeg to 2.5.0
 * Update orc to 0.4.33
 * Update srt to 1.5.3
 * Update taglib to 1.13.1
 * Update zlib to 1.3.1
 * and more 3rd party updates
 * libmpeg2, libdca and liba52 are no longer build by default
 * build ragel inside harfbuzz if necessary
Misc:
 * gnutls: remove manual DH prime bits setting
 * Avoid very large fonts in portrait mode
 * Update of most translations
Many thanks to the Sovereign Tech Agency (https://www.sovereign.tech/), and
especially their Sovereign Tech Fund program, for helping VLC sustainability and safety.
Thanks to oss-fuzz as well for their help and resources to find issues.
Thanks to their support, 3.0.22 becomes the VLC release with the most security fixes ever!
Security:
 * Heap Buffer Overflow READ in TY, NSV, CVDsub, SPU, Subrip, TX3G, MPJEG demuxers and decoders
 * Heap Buffer Overflow Write in RLE, MP4, TX3G demuxers and decoders
 * Assert failure in AVI, MP4 demuxers and Core
 * Null dereferences in CSS, Flac and VTT modules
 * Use-after Free in SVG decoder
 * Crash in Subtitles core, in jpeg2 inside TS
 * Multiple crashes and OOB in CEA-708 subtitles
 * OOB read on Oggspot, MP4
 * Multiple leaks in MKV, ASF/WMV, CAF and PS demuxers, WebVTT and SVCD decoders
 * Busy loop in WebVTT
  (The list above is not exhaustive)
Codice:
Changes between 3.0.21 and 3.0.22:
Core:
Windows:
Decoders:
Demuxers:
Input:
Interface:
 * Qt: Add option to use dark palette
 * Qt: Add compilation support for newer versions of Qt5
 * macOS: fix crashes when drag'n drop items in the playlist
 * KDE: fix MPRIS state when started from file
Service Discovery:
Video Output:
Video Filter:
Contrib:
Misc:
Security:
 * Multiple leaks in MKV, ASF/WMV, CAF and PS demuxers, Ogg, Theora, Vorbis,
Scusate, da dove si scarica?
Trovo ancora la .21 sul sito ufficiale
E' ancora in testing...
Se proprio la vuoi provare (ma aspetterei)
Versione per windows 64 bit (testing)
http://ftp.videolan.org/pub/videolan/testing/3.0.22/win64/vlc-3.0.22-win64.exe
VLC 3.0.22 (02/12/25)
Disponibile VLC 3.0.22
Versione per windows 32 bit
https://get.videolan.org/vlc/3.0.22/win32/vlc-3.0.22-win32.exe
https://get.videolan.org/vlc/3.0.22/win64/vlc-3.0.22-win64.exe
Portable version windows 32 bit
https://get.videolan.org/vlc/3.0.22/win32/vlc-3.0.22-win32.7z
Portable version windows 64 bit
https://get.videolan.org/vlc/3.0.22/win64/vlc-3.0.22-win64.7z
N.B. Non ancora aggiornata pagina ufficiale VLC dei download
Aggiornamento pagina a breve....
https://www.videolan.org/vlc/
Ci credo che è la più piena di "fix", la 3.0.21 è uscita da anni... Non ne ricordo una più longeva come ultima stabile.
edit: ah beh 1 anno e mezzo, sbirciando in quelle pagine, pensavo di più. Comunque tanto tempo
