NI. Quando io registro con il software AverTV in
formato sorgente su Rai HD e quando poi analizzo il file con
Mediainfo Lite mi vengono fuori questi dati
Codice:
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 360 MiB
Duration : 5mn 1s
Overall bit rate mode : Variable
Overall bit rate : 10.0 Mbps
Encoded date : UTC 2012-12-14 22:52:59
Tagged date : UTC 2012-12-14 22:52:59
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=4, N=16
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 5mn 1s
Source duration : 5mn 1s
Bit rate mode : Variable
Bit rate : 9 894 Kbps
Maximum bit rate : 10.2 Mbps
Width : 1 920 pixels
Height : 1 088 pixels
Original height : 1 080 pixels
Display aspect ratio : 16:9
Original display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 38.004 fps
Original frame rate : 25.000 fps
Minimum frame rate : 25.000 fps
Maximum frame rate : 50.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.125
Stream size : 355 MiB (99%)
Source stream size : 355 MiB (99%)
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 5mn 1s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 4.60 MiB (1%)
Source stream size : 4.60 MiB (1%)
Language : English
mdhd_Duration : 301546
(In questo caso è il video relativo ad una registrazione dell'ultimo Telethon in HD nativo)
Non credo però che sia il vero formato nativo, soprattutto per l'audio. Ecco, per l'audio ho perfino un problema con l'applicativo software che non mi fa più ascoltare l'audio dolby, ma questo è un altro discorso....
