In Rilievo EBSpro – la guida PDF in Italiano by PantaSat
Di questi tempi ben vengano queste piccole novità.
Ultimamente ne stanno uscendo veramente pochissime!
Sperando che Crazycat esca sano e salvo dalla sua Ucraina.
è l'unico che sà dove metter mano per far funzionare al meglio queste Pc card.
Perchè se aspettiamo TBS che sviluppi o migliori qualcosa a livello software siamo a posto.
EBSPRO V18.0.0.2 (RC) HAS BEEN RELEASED
18.0.0.2 (RC) [3 jun 2022]
- Improved first load time for big databases.
- Reworked how reports are loaded from db (also bugfixing)
- Show and store channels names in blindscan list when sidepanel is in use.
- Added a link to open streamreader.ini to fine tune some option if is needed.
- Added a workaround 'Raw data handling (no use internal filter)' just for experiments and debug.
- Add Wait-0 automatically when setting up an USALS system or Diseqc 1.2 (you can delete if you don't want to use it).
- Reset blindscan result sort by default before new blindscan.
- Improved TS Grabber behavior and small fixes.
- Improvements in Circular Left/Right handling.
- Improved max SNR reset/detection/algo.
- Check TEI status for validate TS packets in Filters handling.
- Fixes in the internal TS handling for some devices that makes stream unstable.
- Fixes and better support for S2X.
- Fixed LOF value not set under certain scenarios, so can show wrong freq values.
- Fixed Blindscan crash if blindscan list is sort and sidepanel is in use.
- Fixed odd/even k*y handling for CSA and small improvement handling k*ys.
- Fixed TSA timeout problem.
- Fixed issue with the signal lost for vertical band after diseqc 1.2 commands.
- Fixed TCP network issues after second connection.
- Fixed a small costmetic bug with Modulation and rollof.
- Fixed video playing issue with chroma subsampling (need test!)
- Sync_counter fixed.
- General small fixes and improvements.
Ho questo problema con RF scan la info mi nasconde i dati del transponder non te lo fa? Se nello stesso momento premo il tasto Alt mi visualizza le info in quel punto, secondo te da cosa dipende?
oppure ho scoperto che devo tenere premuto il pulsante sx del mouse
No, da me non lo fa.
Ma da quello che ho capito è che ogni modello di TBS fa a se.
Quel programma è stato concepito e ottimizzato per la TBS6983, tutte le altre TBS potrebbero comportarsi diversamente.
E ho notato che non sempre nuove versioni portano reali benefici.
A volte si peggiora.
Ma per eventuali problematiche ti conviene chiede direttamente a lui sul suo Blog, utilizzando disqus
grazie concordo, son tornato alla 18.0.0.0 non ci sono migliorie che mi interessano indipendentemente dal problemino segnalato.
EBSPRO V18.0.0.3 (STABLE) HAS BEEN RELEASED
> 18.0.0.3 (stable) [11 july 2022]
- Added an option to force 18V on profile change when diseqc1.2/usals are defined to speedup motor when is needed (This feature needs StreamReader 1.2.4.129 at least)
- Enhanced Wait dialog info for diseqc 1.2/usals switching.
- Added menu option to set B**S/DC* key in TSA context menu from Signal Analyzer (no need to blindscan first to check a known feed)
- Moved "sounds" checkbox option to main window.
- Mobile: Show LinkMargin/LinkQuality in status.
- Mobile: Refresh device selected in EBSpro Mobile if is changed locally.
- Mobile: No show BER without signal lock.
- Mobile: Faster TSA service scan and make it more reliable.
- Mobile: Always show tuner info, even without lock or transponder selected in Mobile.
- Mobile: Show service names en status.
- Mobile: Now, if you try to use SatFeeds in EBSpro Mobile it will load the last scan report transponders if is available instead.
- Mobile: Show SNR saved in database for comparison when you are adjusting the dish (for reference) in status.
- Mobile: Show CodingMode in transponder list.
- BISS2 CA ID 0x2610 detection.
- TEI counter should count only if is in ts sync.
- Fix random GOLD PLS change in SA (?)
- Some more improvements in key handling.
- Some improvements in the a/v player.
- Total rewrite of how windows form position and size are handled.
- Update: Streamreader.dll to 1.2.4.129 (thanks to @crazycat)
DOWNLOAD qui
18.0.0.4 (stable) [16 july 2022]
- Fixed a small problem handling windows size for some users and better multi-monitor handling.
- Update: Streamreader.dll to 1.2.4.133(thanks to @crazycat)
download qui
Scusate se riprendo questa discussione del 2022 ma mi sembra non OT (oltretutto credo che EBSPRO rimanga sempre il miglior software di analisi, non vi pare?).
Sto cercando di usare le funzionalità presenti in auto-config di "VLC - HTTP output from VLC" (con MP4 format e non) ma nel mio caso si limita ad aprire VLC senza far partire nulla.
IL "VLC (TCP stream)" funziona perfettamente. Qualcuno lo usa/ l'ha usato?
Un saluto a tutti, sapete come si imposta Ebspro per impianto con LNB SCR ? Grazie :icon_bounce:
se guardi i parametri che imposta
Codice:
{proto}://@:{net_port} :meta-title="{sat} @ {dev}" :meta-author=Cjcr-Software :meta-artist="{freq} {pol} {sr} / RF: {rflevel} SNR: {snr}" :meta-copyright="EBSpro" :input-timeshift-path="{data_folder}" :input-record-path="{data_folder}" :no-input-record-native --snapshot-path="{data_folder}VLC_snapshot.jpg" --snapshot-format=jpg :sout=#transcode{vcodec=h264,vb=500,fps=25,scale=0,acodec=mpga,ab=128,channels=2,samplerate=44100}:http{dst=:8080/ebspro.ts} :ttl=10 :sout-keep
si vede che esporta il flusso sulla porta 8080 nel file ebspro.ts e quindi non ti dovrebbe far vedere nulla. Il problema è che anche il flusso esterno non va nonostante la porta 8080 venga aperta.
