Info su GTMedia V7 S2X
Rai 4 HD sui 12606 V SR 35300 Stream 5 - Rai Mux B T2MI è trasmesso in HEVC h.265 come pure Rai 1- Rai 2 -Rai 3 provvisori, pertanto se il GT-Media V7 S2X non può visualizzare H265 perché non implementato a livello hardware, non puoi fare niente per renderli visibili...
Con il GT Media V8X è visibile. allego log con tutte le info del canale ricavate da una breve registrazione.
General
Complete name : E:\PVRS\Rai 4 HD-2024-08-28 07-59-29.ts
Format : MPEG-TS
File size : 9.91 MiB
Duration : 15 s 448 ms
Overall bit rate mode : Variable
Overall bit rate : 5 384 kb/s
Frame rate : 50.000 FPS
Video
Menu ID : 1056 (0x420)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4.1@Main
Codec ID : 36
Duration : 15 s 180 ms
Bit rate : 4 536 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.044
Stream size : 8.21 MiB (83%)
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : 6
Duration : 15 s 168 ms
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : -316 ms
Stream size : 711 KiB (7%)
Language : Italian
Service kind : Complete Main
Dialog Normalization : -27 dB
compr : -3.66 dB
cmixlev : -3.0 dB
surmixlev : -3 dB
mixlevel : 81 dB
roomtyp : 3
ltrtcmixlev : -3.0 dB
ltrtsurmixlev : -3.0 dB
lorocmixlev : -3.0 dB
lorosurmixlev : -4.5 dB
dialnorm_Average : -27 dB
dialnorm_Minimum : -27 dB
dialnorm_Maximum : -27 dB
Audio #2
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 15 s 24 ms
Bit rate : 64.0 kb/s
Channel(s) : 1 channel
Frame rate : 41.667 FPS (1152 SPF)
Delay relative to video : -166 ms
Stream size : 117 KiB (1%)
Language : oth
Audio #3
Format : MPEG Audio
Codec ID : 3
Duration : 15 s 96 ms
Bit rate : 128 kb/s
Channel(s) : 2 channels
Delay relative to video : -238 ms
Stream size : 236 KiB (2%)
Language : English
Menu
Format : HEVC / AC-3 / MPEG Audio / MPEG Audio / / / / / /
Duration : 15 s 198 ms
List : 206 (0xCE) (HEVC) / 306 (0x132) (AC-3, Italian) / 406 (0x196) (MPEG Audio, oth) / 506 (0x1FA) (MPEG Audio, English) / 606 (0x25E)-100 () / 606 (0x25E)-777 () / 606 (0x25E)-778 () / 2002 (0x7D2) () / 3002 (0xBBA) () / 3101 (0xC1D) ()
Language : / Italian / oth / English
Service name : Rai 4 HD
Service provider : Rai
Service type : reserved for future use
General
Format : MPEG-TS
Video
Format : HEVC
Codec ID : 36
Color space : YUV
Bit depth : 8 bits
Audio #1
Format : AC-3
Codec ID : 6
Bit rate : 384 kb/s
Language : Italian
compr : -3.66 dB
cmixlev : -3.0 dB
surmixlev : -3 dB
mixlevel : 81 dB
roomtyp : 3
Audio #2
Format : MPEG Audio
Codec ID : 3
Language : oth
Audio #3
Format : MPEG Audio
Codec ID : 3
Bit rate : 128 kb/s
Language : English
Menu
Ok grazie
Ho il V8 Pro 2 da cinque anni e mezzo ed oltre al multistream riceve anche l' HEVC.
Come ha potuto la GTMedia realizzare il più recente V7 S2X col DVB-S2X ma senza l' HEVC ? :eusa_think:
Un motivo potrebbe stare nel prezzo del chip utilizzato e quindi nel prezzo finale dell'apparecchio, il V7 S2X generalmente (offerte escluse) costava meno del GT Media V8X...
Anche il V8 Finder 2 uscito sul mercato in tempi relativamente recenti (che si dovrebbe basare sullo stesso chip del V7 S2X) non è HEVC 265... e su quei canali da lo stesso messaggio: Not support H265, ma a me non interessa e ne ero consapevole prima di acquistarlo, sia perché appunto ho 2 GT Media V8X DVB-S2X -T2mi-H265 sia perché il V8 Finder 2 non l'ho preso per usarlo come decoder per la TV , poi le misure le mostra ugualmente anche se con schermo nero... anche il V8 Finder 2 costa/ costava abbastanza poco rispetto ad apparecchi similari o veri e propri cloni (ma non con le stesse caratteritiche).
