Nokia 9701s v.72. [Mercury Edition] - NDS Official Card compliant
This issue is based on v.72 Nokia (UnOfficial).
Ecco Le Caratteristike :
MAIN FEATURES - ver NDS
This is a first "incomplete & experimental" release. So there are very limitations and bugs!
In any case, these are new functions:
a) - NDS card enabled! (Only for SKY ITA, not UK)
- Don't forget update ECM pids on nds/sky channels. Old seca2 pids doesn't work!).
This issue don't manage EMM, so periodically you have to update card using a normal skybox!.
- At boot phase, decoder automatically switch to NDS/SECA reading ATR of card inserted
into slot2.
- Remember to set the right ECM pids for NDS channels and set EMU to ON (Menu Settings).
Menu setting has Trace option for NDS. If this option is ON, the video imagine is very
bad, cause the low speed of CPU.
b) now 9701S descramble also BISS channels (Thanks to bBox guys!)
c) management of tpscrypt2/AES ***. (Thanks to bBox guys!)
Firmware append ***00 and ***01 of provider 007C0.
d) Nagra algo modified in order to manage correctly E1,N1,N2 mods (Thanks to bBox guys!)
d) new n9701K.exe program usefull to upload only EMUKEYS record in flash2 (faster than
upload all flash2. ( set port in .INI file). (Thanks to "MC m_auro1")
e) picbin.ini file for picbinedit, updated with full EMUKEYS record formats!
f) other? self-discovering!
NB: refer to "Faq_rev04.txt" for known bugs!
http://www.webalice.it/killer_forever/Nokia9701_Murcury_ndz.zip
»-(¯`v´¯)-A©®1S->
into slot2.
»-(¯`v´¯)-A©®1S->
