Nuovo FW per 3100HD
Sembra che ora sia possibile riprodurre i file multimediali presenti sul pc, usando la connessione LAN e il tool STB Daemon.
Ho provato, ma nonostante il decoder veda i file non li riproduce :eusa_think:
Dev'essere un bug, questa caratteristica era gia stata implementata nella versione 114, con lo stesso risultatato cioè i file non vengono riprodotti.
Col fw 115p dovrebbero essere spariti i problemi di registrazioni a scatti sui canali Sky HD.
Inoltre se il decoder è in modalità stand-by standard, quando si da corrente, non si accende più su un canale, ma compare l'ora a 02:00.
Uscito il 116 original
Fixed : Youtube access condition changed recently.
Fixed : Specific USB 500GB HDD’s are not working for timeshift.
Download
Uscito il 120 original
Changelog:
1. Recording:
when you press power button before finishing the record, changed “YES/NO/CANCEL” to “YES/NO/EXTEND”
YES – Stop recording and Power off.
NO- To cancel Power off, it means it keeps Power ON.
EXTENDED – will not power off immediately, but after completing recording, it goes to Standby Mode automatically.
2. EPG
- STB can save the EPG data for the watching channel currently
Because our STB receives the EPG as TP, so when channel changed, STB can receive the EPG data
- EPG data for current watching channels will save when goes to Standby model and it’s temporarily.
- if set receiver A/C Power off using power switch off or take out power cable, the EGP data will not save in USB.
And the previous saved EPG data in USB will also be removes.
- when watching channel, then EPG data saved in USB and goes to Standby and turn on STB, then STB will bring the saved EPG from USB.
- S K Y UK and FREESAT EPG DATA loading by Astra 28.2E 11.778V !
Note: EPG Solution not final. Something under construction
3. Internet Radio access and search problem fixed
Download
