Paramount Comedy
Queer eye for the straight guy
Qualcuni di voi sa se Paramount trasmetterà da oggi solo le repliche? Dando un'occhiata alla programmazione non ci sono più puntate inedite anche se la serie non era ancora finita. Peccato perchè lo trovavo molto divertente!!
_TeRmInEt_ ha scritto:
Codice:
***    PVAStrumento 2.1.0.15
***      running at 05-01-2006 16:59
      Pre-Scanning input. Takes some time.
Stream info for
C:\Downloads\Paramount Comedy - Frasier - 01_05_06.ts
Found 1 video stream.
Found 2 MPEG audio streams.
VIDEO #1
    Resolution 544 x 576
    Aspect ratio is 4:3
    Frame rate 25.00 fps
    Nominal bitrate 10000000 bps
    First PTS: 10:14:25.119
MPEG AUDIO #1
    MPEG1, Layer 2
    joint stereo, sampled at 48.0 kHz.
    Bitrate 160 kbps
    Each frame contains 24.0 ms audio (480 bytes)
    First PTS: 10:14:24.421
MPEG AUDIO #2
    MPEG1, Layer 2
    Bitrate 192 kbps
    Each frame contains 24.0 ms audio (576 bytes)
==SCANNING==
      Input: C:\Downloads\Paramount Comedy - Frasier - 01_05_06.ts
      Closing starting GOP.
      Aiming for sync at 10:14:25.199
      Cutting audio.
      Audio stream 1 now starts at 10:14:25.189
      Audio stream 2 now starts at 10:14:25.189
      Video stream 1 now starts at 10:14:25.199
ALERT> Audio 1: 3 audio frames missing at 10:27:48.159
      Catching up on audio 1: 3 silent frames.
ALERT> Temporal structure wrong in GOP at 10:27:48.239. Dropping.
ALERT> 1 video frames missing at 10:27:48.239.
ALERT> Dropping GOP for sync.
      Re-syncing.
      Aiming for sync at 10:27:48.719
      Cutting audio.
      Audio stream 1 now starts at 10:27:48.709
      Audio stream 2 now starts at 10:27:48.709
      Video stream 1 now starts at 10:27:48.719
ALERT> Audio 2: 2 audio frames missing at 10:33:50.079
      Catching up on audio 2: 2 silent frames.
ALERT> Audio 2: -1 audio frames missing at 10:33:50.559
      Last fileset:
          586821548 total bytes written
          Video 1: 45020 frames, 00:30:00.800
          Audio 1: 75034 frames, 00:30:00.816
          Audio 2: 75036 frames, 00:30:00.864
      Sync estimate at EOF:
           MPEG Audio #1 : 1 ms before video
           MPEG Audio #2 : sync
      Video statistics
         GOP length (min/avg/max):
                   10 / 11 / 12  [frames]
                   49391 / 135197 / 321895  [Bytes]
         GOP bitrate (min/avg/max):
                   823 / 2253 / 5364 [kbps]
(Autosaving log to /dev/null.txt)
Cannot save to /dev/null.txt
Nessuna idea?
Sì, stesso identico problema. Purtroppo c'è poco da fare se non sperare che sistemino le cose alla fonte.
Ti ringrazio della risposta almeno ora so che non dipende da me ;)
Ho anche notato che lo stesso problemi si ha per tutti i canali di questo tp, veramente strana sta cosa...
