davide63 ha scritto:
Prova con il nuovo firmware:
Vantage HD 6000/7100/8000
English
Before you use the Software please make factory after update to new software
reset for use new functions.
Take care make SYS backup before reset.
Open Menu/Software Manager/yellow button
06.10.2008 Version 02.36T-O
EPG search improved.
Audio problem after switching fixed.
DHCP problem fixed.
Alphacrypt update over menue possible.
Timeshift hang up bug fixed.
New keyboard design..
File rename/move/directory create functions are possible in Vantage player.
Fast reservation in Guide possible. Please choose the event and press rec button. For delete press again the rec button.
Sometime HDD was not reconized. Bug fixed.
Sometime there was 0 Byte recording. Bug fixed..
Timer changed..
Timermenue enhanced
New speeds are included. >> FFW up to 64 fach, << REW up to 16 fach.
Slow motion mode 1/4 and 1/8 are included.
New option for easy System and Channellist backup and Recovery. Channel Setup/Software Manager
In Playback mode you can jump minutes with RCU keyboard.
Password for formatting added.
Radiochannel switchtime improved.
German OSD translation. Change
When USB stick was use on Apple and then use with Vantage Player the STB makes reboot. Bug fixed.
Green Power Fix. Green Power hdd working. But we suggest CE HDD from Seagate.
FTP connection over FTP client SW for example Filezilla. You must connect as anonymous without password
When you press the FAV Button then you will see list of Favorites.
Unicable 4 channel fix
When you exit Vantage Player then no more question that you want to exit.
Niente da fare, anche con l' ultimo fw.
Questo feed mi si blocca in continuazione
World Cup 2010 Qualifiers: Poland - Czech Republic
Eutelsat W3A (7.0°E)
11181 V 27745 3/4 id: POL-051
MPEG-2 4:2:0 55Mbps DVB-S2 (8PSK)
HD Feed for TVP HD
Questo feed è ok e lo vedo senza problemi
Metropolitan Opera: Salome in HD
Atlantic Bird 3 (5.0°W)
11046 V 12891 ID: MET OPERA 11/10/08
MPEG-2 4:2:0 16Mpbs AC3 5.1
Feed For Cinemas
Intelsat 10-02 (1.0°W)
11530 V 12891 ID: MET OPERA 11/10/08
11514 V 12891 ID: MET OPERA 11/10/08
MPEG-2 4:2:0 16000 kpbs AC3 5.1
Feed For Cinemas
Puchar Ekstraklasy: Jagiellonia Białystok - Legia Warszawa
Atlantic Bird 1 (12.5°W)
12616 H 8570 id: Pol_058
MPEG4 AVC 18,4Mbps DVB-S2 8PSK
Feed for Polsat Sport HD
Quando il bitrate dei feed supera i 22 Mbps l' immagine non va e scatta, per valori inferiori non ci sono problemi. Da un' aulteriore analisi posso affermare di avere problemi con i canali HD DVB-S2 e non con i canali HD DVB-S. Se non sbaglio il VANTAGE S 8000 HD è in grado di visualizzare correttamente i segnali HD DVB-S2....
Può dipendere dall' LNB? Può essere il cavo coassiale? Può essere che il ricevitore sia difettoso?
