ma solo a me va bene??![]()
Le segnalazioni al riguardo sono aumentate in rete ,è un bug di youtube che ha colpito solo una parte degli utenti
We're currently working to resolve an issue where videos start playing with the sound muted by default. As we investigate, please try adjusting the volume slider in the bottom left corner of the video player to enable sound. Alternatively, you can try viewing the video in HTML5 by opting into the HTML5 trial http://www.youtube.com/html5.
Instead of clicking directly on the speaker icon, try moving your cursor over the icon to see if the volume slider bar next to the speaker appears.
If it does, then click on the slider -- which appears in the second image, and drag it to the right.
http://support.google.com/youtube/known-issues/16903?hl=en:
This will not solve the issue permanently on any browser. Plus, the standard 100k LSO file limit is more than adequate. In fact, try it yourself. Then delete Flash cookies or Local Stored Object. Specifically, the folder "s.ytimg.com". Refresh or restart your browser. You'll get the same muted volume on the first YouTube video. In fact, every YouTube video will be muted "until" you move the volume slider on one video, which loads the required Flash cookie(LSO) "soundData.sol" locally, setting the player's volume level for all other YouTube videos to reference. Just don't delete this Flash Cookie, and you won't have the mute problem.
Nothing is going to work permanently until YouTube fixes it on their end. The only thing you can do is set the volume level on the first YouTube video. Then make sure you do not delete the Flash Cookie(LSO) folder "s.ytimg.com" containing the volume level data LSO "soundData.sol".
