Puntamento quad feed 7-13-16-19!!
Ho provato diseqctester , x quello che puo valere........
e questo è il risultato:
Orbital position 90:
9.0E Ku-band Eutelsat 9B & Ka-Sat 9A, High Band, V:
Tested 1 transponders
1 (100 %) transponders succeeded
0 (0 %) transponders failed
Successfully tuned transponders' previous planes:
No transponder tuned ==> 9.0E Ku-band Eutelsat 9B & Ka-Sat 9A, High Band, V
complete transponderlist:
(11727, 30000, 1, 3, 2, 90, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 32603, 'tuner_bit_error_rate': 0, 'tuner_locked': 1, 'tuner_state': 'LOCKED', 'tuner_signal_power': 62913, 'tuner_signal_quality_db': 796, 'tuner_synced': 1}
9.0E Ku-band Eutelsat 9B & Ka-Sat 9A, High Band, H:
9.0E Ku-band Eutelsat 9B & Ka-Sat 9A, High Band, V ==> 9.0E Ku-band Eutelsat 9B & Ka-Sat 9A, High Band, H
(11747, 30000, 0, 3, 2, 90, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 34201, 'tuner_bit_error_rate': 0, 'tuner_locked': 1, 'tuner_state': 'LOCKED', 'tuner_signal_power': 61602, 'tuner_signal_quality_db': 835, 'tuner_synced': 1}
Orbital position 130:
13.0E Hotbird 13B/13C/13E, High Band, H:
9.0E Ku-band Eutelsat 9B & Ka-Sat 9A, High Band, H ==> 13.0E Hotbird 13B/13C/13E, High Band, H
(11747, 27500, 0, 3, 2, 130, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 54967, 'tuner_bit_error_rate': 0, 'tuner_locked': 1, 'tuner_state': 'LOCKED', 'tuner_signal_power': 62913, 'tuner_signal_quality_db': 1342, 'tuner_synced': 1}
13.0E Hotbird 13B/13C/13E, High Band, V:
13.0E Hotbird 13B/13C/13E, High Band, H ==> 13.0E Hotbird 13B/13C/13E, High Band, V
(11727, 29900, 1, 3, 2, 130, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 54967, 'tuner_bit_error_rate': 0, 'tuner_locked': 1, 'tuner_state': 'LOCKED', 'tuner_signal_power': 62913, 'tuner_signal_quality_db': 1342, 'tuner_synced': 1}
13.0E Hotbird 13B/13C/13E, Low Band, V:
13.0E Hotbird 13B/13C/13E, High Band, V ==> 13.0E Hotbird 13B/13C/13E, Low Band, V
(10719, 27500, 1, 3, 2, 130, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 49397, 'tuner_bit_error_rate': 0, 'tuner_locked': 1, 'tuner_state': 'LOCKED', 'tuner_signal_power': 62913, 'tuner_signal_quality_db': 1206, 'tuner_synced': 1}
13.0E Hotbird 13B/13C/13E, Low Band, H:
13.0E Hotbird 13B/13C/13E, Low Band, V ==> 13.0E Hotbird 13B/13C/13E, Low Band, H
(10727, 30000, 0, 3, 2, 130, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 46980, 'tuner_bit_error_rate': 0, 'tuner_locked': 1, 'tuner_state': 'LOCKED', 'tuner_signal_power': 62258, 'tuner_signal_quality_db': 1147, 'tuner_synced': 1}
Orbital position 160:
16.0E Ku-band Eutelsat 16A, Low Band, V:
Tested 3 transponders
0 (0 %) transponders succeeded
3 (100 %) transponders failed
The 3 unsuccessful tuning attempts failed for the following reasons:
tune_failed: 3 transponders failed
tune_failed previous planes:
13.0E Hotbird 13B/13C/13E, Low Band, H ==> 16.0E Ku-band Eutelsat 16A, Low Band, V
(10727, 30000, 0, 3, 2, 130, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (10972, 27500, 1, 7, 2, 160, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
16.0E Ku-band Eutelsat 16A, Low Band, V ==> 16.0E Ku-band Eutelsat 16A, Low Band, V
(10972, 27500, 1, 7, 2, 160, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (11011, 27500, 1, 7, 2, 160, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
(11011, 27500, 1, 7, 2, 160, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (11055, 27500, 1, 8, 2, 160, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
(10972, 27500, 1, 7, 2, 160, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
(11011, 27500, 1, 7, 2, 160, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
(11055, 27500, 1, 8, 2, 160, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
16.0E Ku-band Eutelsat 16A, Low Band, H:
16.0E Ku-band Eutelsat 16A, High Band, V ==> 16.0E Ku-band Eutelsat 16A, Low Band, H
(10721, 30000, 0, 3, 2, 160, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 27852, 'tuner_bit_error_rate': 0, 'tuner_locked': 1, 'tuner_state': 'LOCKED', 'tuner_signal_power': 63568, 'tuner_signal_quality_db': 680, 'tuner_synced': 1}
16.0E Ku-band Eutelsat 16A, High Band, H:
1 (33 %) transponders succeeded
2 (67 %) transponders failed
The 2 unsuccessful tuning attempts failed for the following reasons:
tune_failed: 2 transponders failed
16.0E Ku-band Eutelsat 16A, Low Band, H ==> 16.0E Ku-band Eutelsat 16A, High Band, H
(10721, 30000, 0, 3, 2, 160, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (12562, 30000, 0, 2, 2, 160, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
16.0E Ku-band Eutelsat 16A, High Band, H ==> 16.0E Ku-band Eutelsat 16A, High Band, H
(12562, 30000, 0, 2, 2, 160, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (12570, 3703, 0, 5, 2, 160, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
(12562, 30000, 0, 2, 2, 160, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
(12570, 3703, 0, 5, 2, 160, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
(12604, 29980, 0, 2, 2, 160, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 27852, 'tuner_bit_error_rate': 0, 'tuner_locked': 1, 'tuner_state': 'LOCKED', 'tuner_signal_power': 58326, 'tuner_signal_quality_db': 680, 'tuner_synced': 1}
16.0E Ku-band Eutelsat 16A, High Band, V:
16.0E Ku-band Eutelsat 16A, Low Band, V ==> 16.0E Ku-band Eutelsat 16A, High Band, V
(12541, 19970, 1, 3, 2, 160, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 27852, 'tuner_bit_error_rate': 0, 'tuner_locked': 1, 'tuner_state': 'LOCKED', 'tuner_signal_power': 60292, 'tuner_signal_quality_db': 680, 'tuner_synced': 1}
Orbital position 192:
19.2E Ku-band Astra 1KR/1L/1M/1N, Low Band, V:
16.0E Ku-band Eutelsat 16A, High Band, H ==> 19.2E Ku-band Astra 1KR/1L/1M/1N, Low Band, V
(12604, 29980, 0, 2, 2, 160, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (10729, 22000, 1, 2, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
19.2E Ku-band Astra 1KR/1L/1M/1N, Low Band, V ==> 19.2E Ku-band Astra 1KR/1L/1M/1N, Low Band, V
(10729, 22000, 1, 2, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (10758, 22000, 1, 4, 2, 192, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
(10758, 22000, 1, 4, 2, 192, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (10788, 22000, 1, 4, 2, 192, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
(10729, 22000, 1, 2, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
(10758, 22000, 1, 4, 2, 192, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
(10788, 22000, 1, 4, 2, 192, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
19.2E Ku-band Astra 1KR/1L/1M/1N, High Band, V:
19.2E Ku-band Astra 1KR/1L/1M/1N, High Band, H ==> 19.2E Ku-band Astra 1KR/1L/1M/1N, High Band, V
(11798, 27500, 0, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (11778, 29500, 1, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
19.2E Ku-band Astra 1KR/1L/1M/1N, High Band, V ==> 19.2E Ku-band Astra 1KR/1L/1M/1N, High Band, V
(11778, 29500, 1, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (11817, 29700, 1, 2, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
(11817, 29700, 1, 2, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (11856, 29700, 1, 2, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
(11778, 29500, 1, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
(11817, 29700, 1, 2, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
(11856, 29700, 1, 2, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
19.2E Ku-band Astra 1KR/1L/1M/1N, High Band, H:
19.2E Ku-band Astra 1KR/1L/1M/1N, Low Band, H ==> 19.2E Ku-band Astra 1KR/1L/1M/1N, High Band, H
(10773, 22000, 0, 3, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (11720, 27500, 0, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
19.2E Ku-band Astra 1KR/1L/1M/1N, High Band, H ==> 19.2E Ku-band Astra 1KR/1L/1M/1N, High Band, H
(11720, 27500, 0, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (11758, 27500, 0, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
(11758, 27500, 0, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (11798, 27500, 0, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
(11720, 27500, 0, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
(11758, 27500, 0, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
(11798, 27500, 0, 9, 2, 192, 1, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
19.2E Ku-band Astra 1KR/1L/1M/1N, Low Band, H:
19.2E Ku-band Astra 1KR/1L/1M/1N, Low Band, V ==> 19.2E Ku-band Astra 1KR/1L/1M/1N, Low Band, H
(10788, 22000, 1, 4, 2, 192, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (10714, 22000, 0, 2, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
19.2E Ku-band Astra 1KR/1L/1M/1N, Low Band, H ==> 19.2E Ku-band Astra 1KR/1L/1M/1N, Low Band, H
(10714, 22000, 0, 2, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (10744, 22000, 0, 4, 2, 192, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
(10744, 22000, 0, 4, 2, 192, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) ==> (10773, 22000, 0, 3, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1)
(10714, 22000, 0, 2, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
(10744, 22000, 0, 4, 2, 192, 0, 1, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
(10773, 22000, 0, 3, 2, 192, 1, 2, 0, 2, -1, 1, 0, -1, 4096, -1, -1) -- {'tuner_signal_quality': 0, 'tuner_bit_error_rate': 0, 'tuner_locked': 0, 'tuner_state': 'FAILED', 'tuner_signal_power': 0, 'tuner_signal_quality_db': 0, 'tuner_synced': 0}
Infatti i problemi emergono sui 16°E e 19.2°E dove ho alzato leggermente il supporto........ i dubbi che ho alzato un pochino troppo il supporto aumentano.....
Tempo permettendo :) ti e' possibile postare la distanza fra lnb ?
Sembrerebbero sugli 8cm...
grazie
Diluvia, comunque non serve che salga, la distanza da centro a centro è di 78mm, hai un buon occhio. ;)
Il 7E ho dovuto abbassarlo un po', trovato empiricamente, ma non ne capisco il motivo. Forse, e dico forse gli faceva ombra il 13E.
