niente di graveAzure Portal Access Issues
Starting at approximately 16:00 UTC, we began experiencing Azure Front Door issues resulting in a loss of availability of some services. In addition. customers may experience issues accessing the Azure Portal. Customers can attempt to use programmatic methods (PowerShell, CLI, etc.) to access/utilize resources if they are unable to access the portal directly. We have failed the portal away from Azure Front Door (AFD) to attempt to mitigate the portal access issues and are continuing to assess the situation.
We are actively assessing failover options of internal services from our AFD infrastructure. Our investigation into the contributing factors and additional recovery workstreams continues. More information will be provided within 60 minutes or sooner.
This message was last updated at 16:57 UTC on 29 October 2025
non credo sia correlato. il problema di Azure è legato all'accedere al portale per la gestione dei servizi, non il servizio in se. e non mi sembra che le Poste usino AzureDiversi siti web come poste italiane non si aprono per esempio
ah. questo cambia la situazione. coi tempi che tirano, non promettono niente di buono questi attacchi.Non solo poste non si apre, ci sono disservizi più ampi a quanto pare
L'impatto non sembra solo essere sul portale di Azure ma anche alla CDN
non va neanche il sito linkato...Azure Front Door - Connectivity issues
Starting at approximately 16:00 UTC, customers and Microsoft services that leverage Azure Front Door (AFD) may have experienced issues resulting in latencies, timeouts and errors. We have confirmed that an inadvertent configuration change as the trigger event for this issue.
We are taking several concurrent actions: Firstly where we are blocking all changes to the AFD services, this includes customer configuration changes as well. At the same time, we are rolling back our AFD configuration to our last known good state. As we rollback we want to ensure that the problematic configuration doesn't re-initiate upon recovery.
Customers may have experienced problems accessing the Azure management portal. We have failed the portal away from AFD to mitigate the portal access issues. Customers should be able to access the Azure management portal directly, while all portal extensions are working correctly there may be a small number of endpoints that might have a problem loading (i.e. Marketplace).
We do not have an ETA for when the rollback will be completed, but we will update this communication within 30 minutes or when we have an update.
While we dont have an ETA yet. customers can consider implementing failover strategies with Azure Traffic Manager, to fail over from Azure Front Door to your origins: https://learn.microsoft.com/azure/architecture/guide/networking/global-web-applications/overview
This message was last updated at 17:51 UTC on 29 October 2025
