In Rilievo Test Ultra HD 4K su Hotbird 13 est
Da kingofsat leggo che Insight UHD dal 1/09 ha anche la codifica Nagravision. Ma non quella per TivùSat immagino visto che non si apre. Per chi sarà quella codifica Nagra? :)
Su Hot Bird 4K1 c'è un video che è trasmesso in HD e non in 4K. Ma sempre in HEVC:
General
Complete name : D:\PVRS\HotBird 4K1-2022-03-27 16-49-33.ts
Format : MPEG-TS
File size : 62.8 MiB
Duration : 26 s 359 ms
Overall bit rate mode : Variable
Overall bit rate : 19.8 Mb/s
Video
Menu ID : 17 (0x11)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4.1@Main
Codec ID : 36
Duration : 26 s 300 ms
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Writing library : ATEME Titan File 3.8.14 (4.8.14.1)
Audio
Menu ID : 17 (0x11)
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Format version : Version 4
Muxing mode : ADTS
Codec ID : 15-2
Duration : 26 s 304 ms
Bit rate mode : Variable
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : -1 s 144 ms
Language : English
Menu
Menu ID : 17 (0x11)
List : 2701 (0xA8D) (HEVC) / 2702 (0xA8E) (AAC, English)
Language : / English
Service name : HotBird 4K1
Service type : digital television
Per me è in 4k prova a vedere ora.
ID/String : 2701 (0xA8D)
MenuID/String : 17 (0x11)
Format/String : HEVC
Format_Profile : Main 10@L5.1@Main
CodecID : 36
Duration/String : 5s 960 ms
Width/String : 3.840 pixel
Height/String : 2.160 pixel
DisplayAspectRatio/String : 16:9
FrameRate/String : 50,000 FPS
ColorSpace : YUV
ChromaSubsampling/String : 4:2:0 (Type 2)
BitDepth/String : 10 bit
Encoded_Library/String : ATEME Titan File 3.8.14 (4.8.14.1)
colour_range : Limited
colour_primaries : BT.2020
transfer_characteristics : HLG / BT.2020 (10-bit)
matrix_coefficients : BT.2020 non-constant
Il canale si, ma in base alla clip in onda i parametri del canale cambiano. Durante Home TV 4K il canale passa in HD a 1080p HEVC. Infatti ieri l'ho notato per puro caso perchè mi sono sintonizzato sul canale tramite un decoder HD (e non 4K) e si vedeva :D ;)
Con qualsiasi decoder satellitare purchè supporti l'HEVC, ma che non sia 4K. Comunque verificato anche ieri sera su Tv Samsung e confermo il passaggio all'HD durante quei filmati di Home 4K. Qualità video comunque ottima. Magari poi si tratta solo di un errore. Ma così l'hanno "caricato".
È episodica la presenza dello spagnolo, mi sembra, non l' ho trovato, ieri. Solo inglese, francese e russo. Almeno lo spezzone che stavo visionando.
