- 4 Luglio 2011
Dal manuale della MB Asus ROG_STRIX_B450-F_GAMINGCorreggo le ram vengono lette a 2133 mhz,non ho ancora provato a forzarle a 3200,ma mi sembra troppa la differenza,se venissero lette a 2400 o 2600 già buono ma 2133 sono più ddr3
Memory
4 x DIMM, max 64GB, DDR4 3200(O.C.) / 3000(O.C.) / 2933(O.C.) / 2800(O.C.) / 2666 / 2400 / 2133 MHz, un-buffer memory
Memory configurations
The default memory operation frequency its depennt on its Serial Presence Detect (SPD), which is the standard way of accessing information from memory module.
Under the default state, some memory modules for overclocking may operate at a lower frequency than the vendor-marked value.
quindi 3200 MHz solo in overclocking... (profilo DOCP)
