Discussione su Foobar2000
https://www.foobar2000.org/changelog
1.6.14
  • Maintenance release with changes backported from 2.0 series.
  • Made possible to apply DSP config changes without reinitializing affected DSPs.
  • Allowed DSPs to manipulate their shown name depending on preset data.
  • libFLAC 1.4.2, made possible to decode 32 bits per sample FLAC file.
  • Worked around FLAC files with ID3 tags being reported as corrupted by new libFLAC.
  • zlib 1.2.13.
  • Added mitigations for apparent random crash on Wine (less C++ exceptions thrown when dealing with media indexing errors).
Foobar2000 v2.0 beta 14
Disponibile Foobar2000 v2.0 beta 14
https://www.foobar2000.org/download
Beta 14
- Enabled search indexing of file paths by default.
- Because this somewhat affects performance and some people just don't care, an advanced option to turn it off has been added.
- WavPack library update.
- More compatible reading of exotic AIFF files.
- Fixed a very old bug in 8-bit AU writer.
- Added sanitization of internet radio metadata as certain station was serving nonsensical sample rate info.
- Improved compatibility with MP4 files made with yt-dlp.
- Improved compatibility with stripped down Windows 10 distributions.
Foobar2000 v2.0 beta 15
Disponibile Foobar2000 v2.0 beta 15
Beta 15
  • Fixed various library search expression handling bugs.
  • Made FLAC tag updater remove ID3v2 garbage prefixing FLAC stream.
  • Made ERROR_BAD_LENGTH condition crash to debug specific network share compatibility issue.
  • Made MP3 reader report MP3 frame count not matching Xing/LAME header info when verifying integrity.
:5eek:
Non ho capito, ti ritrovi qualche problema con il Dac?
Foobar2000 v2.0 beta 16
Disponibile Foobar2000 v2.0 beta 16
Beta 16
  • Improved compatibility with network shares - worked around specific server refusing GetFileInformationByHandle() resulting in previous foobar2000 v2.0 betas being unable to play or index media from such.
  • More search regression fixes.
  • Fixed missing ES_AUTOHSCROLL in ReFacets search box - was limiting length of typed search pattern to size of the editbox.
  • Added lock toggle to Default UI splitter.
  • Rating field handling fixes - %rating% now looks up rating meta if no rating is present in the database.
  • Reverted larger font in Properties tabs as everyone seems to hate it.
  • Fixed 64-bit setup being unable to close running foobar2000 instance before updating.
  • Fixed archive content being invisible in Album List's folders view, possibly in other components too (library_manager::get_relative_path).
È vero che il driver Asio non serve a niente, cioè non c'è differenza di qualità audio, con quello standard che trovi installato?
Da più parti si dice così ed anche sullo stesso sito del plugin in Foobar 2000, dice che non serve a nulla.
Non serve a nulla secondo me, non trovo differenze.
Nel frattempo ho aggiunto 4 nuove radio con cover collage:
https://www.rmc2.net/webradio/
Immagine-2022-12-03-195623.png"
Immagine-2022-12-03-195711.png"
Immagine-2022-12-03-195735.png"
Immagine-2022-12-03-195801.png"
Io ne ho già aggiunte abbastanza di Radio.
Sostituisco solo quelle dove non funziona più il link o dove c'è una versione con più qualità.
Da un po' sto provando la versione Beta (Portatile) e finora non ha dato problemi.
Però ora preferisco quella più leggera, con i plugin indispensabili, senza sfondi in background, vu meter, YouTube, ecc. o altre cose che appesantiscono il tutto.
La v2 funziona alla grande con le Radio e non solo con le radio :D:
Aggiunte cover collage di m2o webradio e m2o tv:
Foobar2000 v2.0 beta 17
Disponibile Foobar2000 v2.0 beta 17
Beta 17
  • libvorbis is once again used for decoding Vorbis format instead of FFmpeg, as some rare files continue to cause compatibility issues.
  • Default Playlist View: Fixed column size remembering bugs.
  • Updated Properties / Automatically Fill Values logic, better results if searched pattern appears more than once.
  • Fixed missing quotation mark recognition in new library search system.
  • Fixed bad import of old foo_playcount ratings (0.5 added), made first run clean up existing database and badly imported values from the old version.
  • Fixed Console not obeying color settings.
