Discussione su Video LAN VLC
Aggiornato Vlc alla nuova versione 3.0.4 stavolta tramite controlla aggiornamenti del programma stesso. ;)
Ho scoperto che VLC, già dalla versione 3.0.3 è in grado di riprodurre i file .ts, anche le registrazioni di canali codificati, effettuate coi decoder Clarke Tech come l'HD 4100 plus. Prima venivano riprodotti i file .ts realizzati con altri decoder come il Digiquest F777, ma non quelli del Clarke Tech, riproducibili con altri player meno comodi e diffusi.
Io già diversi mesi fa ho scaricato file .ts da internet e vlc li leggeva alla grande [emoji23]
Da giugno circa questo discorso
Vlc 3.0.5
Change log VLC 3.0.5
https://www.videolan.org/developers/vlc-branch/NEWS
Codice:
Changes between 3.0.4 and 3.0.5:
Access:
 * Improve RTSP playback
 * BluRay fixes and improvements, notably for menus and seeking
 * Improve the UDP/RTP truncated issue
Codec:
 * Add a new AV1 decoder based on dav1d library
 * Enable libaom decoder by default
 * Fix decoding of some HEVC streams with macOS hardware decoding
Demux:
 * MP4: Fix reading of some HDR metadata
 * Miscellaneous AV1 demuxing improvements
 * Fix CAF integer-underflow
 * Fix an MKV crash on iOS 12.0, on iPhone XS phones
Packetizer:
 * Add an AV1 packetizer
macOS:
 * Starting with VLC 3.0.5, VLC will be distributed with runtime hardening
   enabled on macOS Mojave.
   All external VLC plugins need to be signed by a DeveloperID certificate in order
   to continue working with the official VLC package.
 * Update the VLC dark UI to better match the dark mode of macOS Mojave
 * Fix convert & save panel stream option
Audio output:
 * Fix corking when the playback state is paused
 * Improve corking on Android
Video Output:
 * Fix Direct3D11 tone-mapping when HDR is displayed on an SDR screen
 * More accurate colors for SD sources in Direct3D11
 * Disable hardware decoding on some old Intel GPUs
 * Fix zero-copy GPU acceleration on AMD RX Vega
 * Misc Direct3D11 fixes
Miscellaneaous:
 * Improve ChromeCast
 * Update numerous 3rd party libraries, including for minor security issues
 * Update Youtube support
 * Fix subtitles rendering with specific fonts with negative horizontal advance
Ma possibile che con la ricerca aggiornamenti non me lo trova mai? Devo sempre installarlo manualmente.
MacOS.
Si, anch'io quando posso aggiorno manualmente, ho trovato solo una volta l'aggiornamento.
Magari non viene messo subito OTN ma solo in un secondo momento
Oh che bello stasera i video mp4 a schermo intero e quando va via la barra informazioni sballano i colori.
Stessi video con un altro lettore che ho provato si vedono bene.
Solo gli mp4.
Ho due ipotesi... o sono i codec ma strano visto che ho provato a resettare e poi a schermo intero si vedono bene o è stato che sto usando la scheda video integrata invece della Asus GT720 che ho smontato.
Qualcuno ha qualche idea in più?
Ho dovuto mettere le 2.2.8 e va bene... che roba strana
Qualche dubbio me lo lascia questa 'riga' del changelog
