A proposito se vai sul git.opendreambox.org non c'è bisogno di aspettare  i changelog leggi i vari commit e sai cosa hanno fatto.
Si ok, ma loro quando inseriscono le info, come quelle che ha postato maumixio, gli costa tanto scrivere 2 righe in più con quello che hanno sistemato o aggiunto?
Una volta lo facevano!
ESEMPIO DI VECCHIE RELEASE
CHANGELOG DM800SE RELEASE 3.2.2
enigma2 (20111110 rel32 -> 20120327 rel32)
- fixed blindscan for non-universal LNBs
- fixed sporadic crash on recording stop
- fixed tag list in serienfilm plugin
- fixed picture errors on loopthrough tuner close
- fixed sporadic crashes on zap between IPTV services
- fixed shared pvr channel allocation (i.e. this fixes the bitrate viewer for recordings)
- fixed timer recordings from IPTV services
- fixed removeServices function
- fixed skipping forward/backward on some MPEG2-content (> 16X)
- fixed e2 shutdown freeze
- added workaround for not visible event titles on ARTE(HD)
- added option to remove all terrestrial / cable services in channel selection context menu
- various mount manager optimizations and fixes, added usb/cf support, also renamed to "storage devices"
- hotplug support is working again (for not explicitly mounted storage devices)
- use "auto" to mount the storage devices to allow non-EXT3 filesystems again
- some teletext subtitle fixes / cleanup
    - calculate screen positions based of original ttx line numbers
    - use more appropriate colors
    - fixed erase of visible subtitles
- updated some translations
- updated default favourite lists
- updated translations
- don't show the infoline(filename) and play icons while in Picture-Player slideshow mode
hardware drivers (20111109 -> 20120328)
- cxd1981 (hybrid DVB-C/-T tuner)
  - increased max. frequency to 900Mhz
  - fixed missing 5V on output for active terrestrial antennas
- bcm4505/6 improved reception sensitivity (fixes problems with small dishes since blindscan support)
- fixed volume boost on audio playback (ALSA)
- fixed overflow on aspect ratio calculation
  this fixes possible wrongly scaled content
- fixed possible TPM initialization problem
bootlogo.elf
- fixed boot problems caused by unreadable HDMI EDID
- don't fall back to DVI for HDMI modes when RX device is not detected or EDID was unreadable
other
- temporarily switch back to old pagecache handling because of a probable bug in the linux 2.6.18 kernel
  (this can improve the read/write performance from/to NAS devices but can degrade the HDD I/O performance)
- fixed timezones: Russia and Belarus no longer use daylight-savings time
- fixed a linux kernel bug which caused deadlocks in some situations (e.g. during media playback or other multithreaded code)
- fixed ac3/dts passthrough problems on media playback
