cirio
Digital-Forum Senior Plus
Dei nuovi arrivati segnalo che 6 SESTARETE TV non si vede ne su pc ne su octagon ma si sente solo audio a scatti.
Per le altre tv tutto OK
Codice:
VideoID : 501 (0x1F5)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 3 frames
Duration : 1 s 0 ms
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Scan type, store method : Interleaved fields
Scan order : Top Field First
