non so' quando uscira' ho fatto una ricerca + approfondita e da quel poco che ho capito sui siti esteri pare ci siano problemi il ricevitore doveva uscire da diverso tempo ti conviene prendere il 200
ho trovato le specifiche ma in rete sono state postate tempo fa boh?
Mvision HD-500 USB - COMBO- NET alle specificaties:
1. Conditional Access Interface
.. SMART CARD 1 Slot
ISO 7816, GSM11.11 and EMV (payment systems) compatibility
.. PCMCIA 2 Slot
DVB Common Interface Standard
(NO FTA,huNO FTA,NO FTA,NO FTA,Crytoworks,AlpahCrypt …)
2. Tuner & Channel(DVB-S) SATELLIET
.. Type 1 × F Type, IEC169-24, Female
.. Frequency Range 950MHz to 2150MHz
.. RF Impedance 75 Ohm unbanlanced
.. Signal Level -65 to -25 dBm
.. LNB Power 13.5/18.5Vdc +/- 5%, 0.5Amax, Overload Protected
.. 22KHz Tone Frequency : 22KHz +/- 2KHz, 0.6Vpp +/- 0.2V
.. DiSEqC Control Version1.0, 1.2, Tone burst A/B, USALS
.. Demodulation QPSK, 8PSK
.. Input Symbol Rate DVB-S QPSK : 1~45 Msps
.. DVB-S2 8PSK/QPSK : 10~30Msps
.. FEC Decoder 1/2, 2/3, 3/4, 3/5, 4/5, 5/6, 8/9, 9/10 in DVB-S2 mode.
1/2, 2/3, 3/4, 5/6 and 7/8 in DVB-S mode.
3. Tuner & Channel(DVB-T) DIGITENNE
.. Type IEC60169-2(VHF/UHF) female, 75Ù nominal
.. Frequency Range VHF: 170MHz to 230MHz
.. UHF: 470MHz to 862MHz
.. Signal Level -78.5dBm ~ -25dBm
.. (64QAM, Code Rate 2/3, Guard Interval 1/8,Gaussian Channel)
.. COFDM Spectrum COFDM 2K/8K-Carrier
.. FEC Mode 1/2, 2/3, 3/4, 5/6, 7/8
4. System & Memory
.. Main Processor STI7109
.. Flash Memory 8 Mbytes
.. System Memory 128 Mbytes
.. Channel Capacity Digital Channel: 5,000
.. Front 7-pepito de ternera, VFD Display 5 Icon, 8 digit Alphanumeric)
5. MPEG Transport Stream & A/V Decoding
.. Transport Stream 13818-1 MPEG-2, H.264/AVC Transport stream Specification
.. Profile Level MPEG-2 MP@ML, MP@HL, MPEG-4 H.264/AVC
Input Rate Max. 90Mbit/s
.. Aspect Ratio 4:3, 16:9, Letter Box
.. Frame Rate 25Hz for PAL, 30Hz for NTSC
.. Video Resolution 576i, 576p, 720p, 1080i
.. Teletext Through VBI
.. Audio Decoding MPEG-1 Layer 1 & 2, Dolby Downmix
.. Audio Mode Single Channel/Dual Channel Joint Stereo/Stereo
.. Frequency Response 20~20kHz, <+/-2dB 60Hz ~ 18kHz <+/- 0.5dB
.. Sampling Rate 32, 44.1, 48KHz
6. A/V & Date In/Out
.. HDMI HD Video/Audio Output
.. TV SCART Output RGB, CVBS, L, R Output with Volume control
.. VCR Scart In/Out RGB, CVBS, L, R In CVBS, L, R Out
.. RCA Output CVBS, L, R Output(Yellow, White, Red Jack) with Volume Control, Component Video(YPbPr) Out
.. S-VHS Output 4 Pin Mini
.. SPDIF Dolby Digital Bitstream Out(Coaxal, Optical)
.. Data Interface - RS-232, Bit Rate: 115,200baud, Connector: 9-pin D-sub Male type
- USB : USB 2.0, Type A Connector, 2Port
.. Network Connection Ethernet 10/100 RJ45
7. RF Modulator
.. RF-Connector 75 ohm IEC 169-2, Male/Female
.. Frequency 470MHz to 860MHz
.. Output Channel CH21 ~ 69 for the Remodulator
.. TV Standard PAL G/I/K Selectable by Menu Setting
.. Audio Output Mono with Volume Control
.. Preset Channel CH 38(or TBD). Software changeable by Menu Screen
8. Power Supply
.. Input Voltage AC 90V ~ 250V, 50Hz ~ 60Hz
.. Power Consumption Max 40W
.. Standby Power Consumption <= 10W
.. Protection Separate Internal Fuse
The input shall the lighting protection
9. Physical Specification
.. Size(WxHxD) 340mm x 68mm x256mm
.. Weight 3 KG
