L'agiornamento sistema la gestione della LCN e una volta aggiornato puoi mettere italia come paese (non Francia o Germania).
Poi come dici tu sistema la compatibilita' con la cam la funzionalita' della guide plus.
Dopo l'aggiornamento ho notato che alcuni parametri di default del video sono cambiati (tipo la retroilluminazione).
Forse anche l'immagine e' migliorata ma magari e' un'impressione.
Se lo porti all'assistenza paghi...se lo fai da te mi raccomando!!!!
Segui le istruzioni alla lettera e pazienta, lo schermo e' nero durante l'upgrade non spegnere o toccare nulla fino a quando non finisce.
FIRMWARE 1512 (Last firmware for 40-46-52 W4000, W4500, x4500)
http://www.megaupload.com/?d=SGAKZX16
MEMORY STICK formater
http://www.sonydigital-link.com/rme/...spx?m=&f=MSFRM
01 - Open the folder named W4000.
02 - Copy the entire folder called se3_proto1 in MEMORY STICK in the root.
01 - Before the UPDATE, switch on your TV, put on a DIGITAL channel (push DIGITAL button near ANALOG button on the remote), then turn off the power button located on TV. It should not be in standby before proceeding.
02 - Disconnect all cables from the TV (HDMI, SCART, YUV, RCA). Only the antenna cable should remain connected.
03 - Disconnect power.
04 - Put the Memory Stick slot in the "SERVICE ONLY" button on the left side.
05 - Reconnect the power supply.
06 - Press the POWER button on the TV.
07 - Wait about 10 to 15 minutes, the screen is black, so do not worry, the LEDs Red, Green and Orange will begin to flash, fade, flash, etc. ...
At 2 minutes, a message "START UPDATE" will appear on the screen for a few seconds, then the screen will be black again.
During the SHIFT, TV reboot 1 or 2 times, it's normal.
08 - Once the setup menu (language selection) appears and only the green POWER light is on, it's over.
VERY IMPORTANT, do nothing until the Memory Stick is still in TV. Do not configure your TV yet. Just hit the power button on the TV.
09 - Disconnect power cable. It is very IMPORTANT.
10 - Remove the Memory Stick.
11 - Reconnect the power supply.
12 - Turn on your TV, the setup menu will reappear, this time you can make your adjustments. If the setup menu does not reappear, make a mandatory RESET TOTAL TV which is in the SETUP menu.
Ho utilizzato una memorty stick pro duo da 1 giga con l'adattatore e non ci sono stati problemi.
R.
