A livello di curiosità ecco i dati che ho raccolto:
[Elenco filtri usati]
(1) Built-in MPEG2 TS Source
(2) Built-in Video Codec/Transform
(3) Enhanced Video Renderer(Custom Present)
(4) Built-in Audio Codec/Transform
(5) DirectSound Audio Renderer
[Informazioni video]
Codec: HEVC - Native D3D9 DXVA Decoder(VLD) - AMD Radeon(TM) Graphics
Tipo di input: HEVC(24 bits)
Dimensioni input: 1440 × 540(3.56:1)
Tipo di output: dxva
Dimensioni output: 1440 × 540(3.56:1)
Frequenza fotogrammi: 50
BitRate: Sconosciuto
[Informazioni audio]
Codec: AAC ADTS(0x4441) - Decoder FFmpeg interno(aac)
Frequenza di campionamento: 24000 ->48000 campionamenti/sec
Bitrate: 0 ->32 bit/campionamento
Canali: 2 ->2 canali
Bitrate: 104 kbps
General
Complete name : D:\_MSTPVR\20250528_230231_[69 Deejay TV HD]_[Deejay Chiama Italia].ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 13.8 MiB
Duration : 1 min 32 s
Start time : UTC 2025-05-28 22:02:34
End time : UTC 2025-05-28 22:04:03
Overall bit rate mode : Variable
Overall bit rate : 1 252 kb/s
Network name : Persidera1
Country : ITA
Timezone : +02:00:00
FileExtension_Invalid : m2ts mts ssif
Video
Menu ID : 40 (0x28)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4@Main
Codec ID : 36
Duration : 1 min 31 s
Width : 1 440 pixels
Height : 540 pixels
Display aspect ratio : 3.556
Frame rate : 50.000 FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 8 bits
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Menu ID : 40 (0x28)
Format : AAC LC SBR
Format/Info : Advanced Audio Codec Low Complexity with Spectral Band Replication
Commercial name : HE-AAC
Format version : Version 4
Format settings : Implicit
Muxing mode : ADTS
Codec ID : 15-2
Bit rate mode : Variable
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 23.438 FPS (2048 SPF)
Compression mode : Lossy
Delay relative to video : -519 ms
Language : Italian
Menu
Menu ID : 40 (0x28)
List : 401 (0x191) (HEVC) / 402 (0x192) (AAC, Italian) / 8131 (0x1FC3) ()
Language : / Italian
Service name : Deejay TV HD
Service provider : Persidera
Service type : advanced codec HD digital television
UTC 2025-05-28 20:30:00 : it
eejay Chiama Italia / it: / music/ballet/dance / / 02:00:00 / Running
UTC 2025-05-28 22:30:00 : it:La musica di Radio Deejay / it: / music/ballet/dance / / 05:30:00 / Not running
Dimensioni input: 1280 × 720(1.78:1)
Dimensioni output: 1280 × 720(1.78:1)
Bitrate: 97 kbps
General
Complete name : D:\vlc-record-2025-05-29-13h25m04s-20250529_065034_[69 Deejay TV HD]_[La musica di Radio Deejay].ts-Deejay Chiama Italia.ts
Format : BDAV
File size : 2.17 MiB
Duration : 14 s 43 ms
Start time : UTC 2025-05-29 08:00:21
End time : UTC 2025-05-29 08:00:34
Overall bit rate : 1 254 kb/s
Country : ITA
Video
Menu ID : 40 (0x28)
Format : HEVC
Format profile :
Main@L4.1@Main
Codec ID : 36
Duration : 13 s 960 ms
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Audio
Menu ID : 40 (0x28)
Format : AAC LC SBR
Muxing mode : ADTS
Codec ID : 15-2
Duration : 13 s 824 ms
Delay relative to video : -642 ms
Language : Italian
Menu
Menu ID : 40 (0x28)
UTC 2025-05-29 08:00:00 : it
UTC 2025-05-29 10:00:00 : it:50 Songs / it: / music/ballet/dance / / 02:00:00 / Not running
Codec: H264 - Native D3D9 DXVA Decoder(VLD) - AMD Radeon(TM) Graphics
Tipo di input: H264(24 bits)
Dimensioni input: 1440 × 1080(1.78:1)
Dimensioni output: 1440 × 1080(1.78:1)
Frequenza fotogrammi: 25
Codec: AAC(LATM)(0x1ff) - Decoder FFmpeg interno(aac_latm)
Canali: 0 ->2 canali
Bitrate: 0 kbps
General
Complete name : D:\vlc-record-2025-05-29-13h28m53s-20250529_065034_[69 Deejay TV HD]_[La musica di Radio Deejay].ts-50 Songs.ts
Format : BDAV
File size : 2.98 MiB
Duration : 11 s 585 ms
Start time : UTC 2025-05-29 10:23:57
End time : UTC 2025-05-29 10:24:06
Overall bit rate : 2 064 kb/s
Country : ITA
Video
Menu ID : 40 (0x28)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference fra : 4 frames
Codec ID : 27
Duration : 10 s 840 ms
Height : 1 080 pixels
Frame rate : 25.000 FPS
Color space : YUV
Bit depth : 8 bits
Scan type : MBAFF
Scan type, store method : Interleaved fields
Scan order : Top Field First
Audio
Menu ID : 40 (0x28)
Format : AAC LC SBR
Format settings : NBC
Muxing mode : LATM
Codec ID : 17-2
Duration : 11 s 264 ms
Delay relative to video : -446 ms
Language : Italian
Menu
Menu ID : 40 (0x28)
List : 401 (0x191) (AVC) / 402 (0x192) (AAC, Italian) / 8131 (0x1FC3) ()
UTC 2025-05-29 10:00:00 : it:50 Songs / it: / music/ballet/dance / / 02:00:00 / Running
UTC 2025-05-29 12:00:00 : it
eejay Time / it: / music/ballet/dance / / 01:00:00 / Not running
UTC 2025-05-31 04:00:00 : it:La musica di Radio Deejay / it: / music/ballet/dance / / 02:00:00 /
