Sdx Chan Editor
Thanks for the report....maybe I understand the error in the function.....working on the patch.
let's try the new release 1.0.10 utilizing the "SALVA" button in main menù on the left; all sectors will be saved in one touch. Also single save button in each module (sat, tp, chan....) now should be working rightly.
OK, here's the deal. When I:
1. change sat only, move them up and down and press this button below to save, it fails to install:
https://prnt.sc/ZcFX6IMB751r
2. change transponder only, and press the button below, it installs OK:
https://prnt.sc/Z4KspDJfdhTR
3. change channel only (I just deleted 1 channel), and press the button below to save, it installs OK:
https://prnt.sc/wt2ezImS6Iw7
4. When I change nothing, just open my untouched file and save it with the button below, it fails to install:
https://prnt.sc/wIPUZCCrPmNN
So, I think this button is the problem, or the function it does.
Can you try the same test with the new release .10 adding that with SALVA button in main menù? Thanks
scusa ma se su un provider ( tivusat esemp.) cambia frequenza un canale come faccio ad editare il canale vecchio sostituendo freq,Sr e polar.???
This one?
https://prnt.sc/zbXwt2D2o1oi
When I click it I get this error:
https://prnt.sc/s9HtUGn5lsE1
And when I create a new satellite and move it and click Agg.Poz.Sat and Salva Sat I get this error:
https://prnt.sc/Ib3HgIrHeD_J
Yes, the button "SALVA" was that.
why do you always find some errors and I never find any in my tests? :ROFLMAO::eusa_wall: ... I rewrote the saving routines to handle a future form. I understand where it gave you both errors...I will try to fix these as well.
devi entrare nella lista canali, posizionarti sul canale che vuoi modificare, tasto destro del mouse e nel menù che ti compare premi MODIFICA... lì hai tutti i parametri del canale e puoi modificarli
scusami se clicco su modifica sul nome del canale esce edit service, canale e transponder, se vado su transponder esce vuoto senza nulla mentre su canale non trovo nulla in merito alla frequenza,etc.
mi fai capire quali dati vuoi modificare così ti aiuto ad individuare l'esatta collocazione dove inserirli (tieni presente che la logica di un file sdx non è quella dell'e2)
esempio il canale Cielo nel bouquet tivusat ha cambiato frequenza da parecchio ma vorrei inserire quella nuova, come si fa?
Per modificare la frequenza devi operare sui transponder; ti visualizzi la lista transponders e poi vai a modificare quello vecchio:
  • in FREQ inserisci: 12073
  • in SR : 29900
  • in POL: 1
  • in FEC: 4
  • in SatIndex: il numero del satellite che hai nella lista satelliti
  • in Netname: come in satindex
Quindi premi SALVA TP e poi SALVA MOD TP su FILE.
