Singapore Android Starhub Cable TV BOX/Combo OTT DVB
4K H .265 DVB-S2+DVB-T2+C(HD)
Main Feature:
Fully Compliant with MPEG-2, MPEG-4/H.264,4k H.265 DVB-S2/T2 Standards
Ethernet for Programs Encrypted by Irdeto/Seca/NDS5.0/Viaccess3.0/Conax7.0u
Irdeto Programs Decrypt Available
supportower vu& biss key&tandberg
IKS:CCcam/OScam/Newcamd/MGcam/Xcam/Redcam
*Account Auto Input Via USB Disk
*Account Manual Input Via Keyboard
BISS/NAGRA/IRDETO Soft key Embed In;Update Soft key by manual input
Smart card for the Decrypt Program :Irdeto/Nagra/Viaccess/Conax/Seca
Android APP Supported
*Browse all video websites ,support Netflix ,Hulu ,Flixster , Youtube c
*Apps download freely form android market , amazon APP store, Office suit and Email
*Local Media playback, support HDD, U Disk
*Support SKYPE video call ,MSN , Facebook ,Twitter
*Free Internet searching, thousands of android applications, many kinds of games
WIFI:
*WIFI Build In, 2.4GMHz
*3.0dB Antenna, Hot Pot
*Soft routing function
*3G Dongle
USB3.0 for PVR:
*Media player: MP3/ JPEG/ BMP Files
*Record: End-time Settings, 2-hour Default
*Time-shift: Fast Forward& Backward, 2/4/8/16/24 pause, Play, Jump to Set Time
~Easy Menu System with both Multi-language and 32 Bit true Color on Screen Display
~5000 TV/Radio Channel Capacity& Last Channel Memory Supported
~Automatic PAL/NTSC Conversion Supported
~7 Days EPG, PIG & PIP Supported
~Subtitle in both DVB EN300743 and EBU Supported
~Teletext in DVB ETS300472 by VBI & OSD Supported
~DiSEqC V1.0 and V1.2 ,V2.0, SCPC and MCPC, C/Ku Band Satellite Supported
~LNB Power Supply& Polarization (Vertical 13V/Horizontal 18V/Maximum 400mA)
~32 Different Favorite Groups Optional & Parental Lock Supported
~Network/Blind/Auto Channel Search Optional
~Various Channel Editing Functions (Favorite, Move, Lock, Rename and Sort) Supported
~Software Upgrade through USB2.0/Ethernet/RS232 Optional
~Time Set by GMT, Automatic/manual Offset, Summer Time-set Supported
1
IPTV:HTTP.RTMP.RTSP
MEDIA PLAY:BLUE-RAY/RMVB/TS/VC-1/DIVX/MKV
HDD:NTFS/FAT32
WiFi EMBEDED:WIFI HOT POT ROUTING
3G.GPRS supported
Miracast::Mirroring the screen of phone or PAD to TV
DlNAushde the video,audio,pictures from phone or network to TV
AirPlayushed the video,audio,pictures from IPHONE or IPAD to TV
LAN:Through the LAN, can check other devices to share information
3D:move Support 3D movie
XBMC:Support
DRM:Optional
ONLINE:Browse all video websites support Netflix ,Hulu Flixster,youtube etc
APPS:Apps download freely from android market amazon appstore etc
Medium:Local Media playback,support HDD,U disk ,SD card
Talk online:support SKYPE video call,MSN,facebook,tiwitter,QQ etc
Avete visto?
Altro che tra 2 anni!!
C'e' gia' un decoder 4K Android!!!
Set top BOX Android Hi 3796 Combo DVB 4K H .265 DVB-S2+DVB-T2+C(HD) Android wifi open box Satellite receiver
US $195.00
Guarda la foto: hdmi 1.4
È il classico 1080p e 4k@30fps senza hdcp 2.2.
Praticamente inutile.
Che io sappia l'HDCP 2.2. lo richiede il decoder al TV, ma se quel decoder non lo chiede...Guarda la foto: hdmi 1.4
Per quanto riguarda l'HDMI 1.4 supporta 3840×2160 (Ultra HD) a 24 Hz/25 Hz/30 Hz
Per me quello che conta in questa discussione non e' tanto uno specifico modello di decoder Android 4K, ma il fatto di sapere che il primo (magari limitato) decoder esiste gia' e la strada e' spianata per il futuro quando IMHO Android sara' inevitabile nei decoder..
Fino a 30 fps dovrebbe essere possibile...L' inutilità di quel decoder sta nel decodificare contenuti in hevc ( 99,999999% in 4k) ma non poterli trasmettere al monitor.
Ma che significa?? Come non trasmette??? Trasmette e come. Solo che fa downgrade
Στάλθηκε από το SM-G935F μου χρησιμοποιώντας Tapatalk
Forse hai ragione.. Anzi, non lo metto in dubbio... Ho detto ciò che ho detto perché avevo in mente il mio caso.o ossia un decoder di genere e una tv full HD. Nel mio caso posso vedere i canali 4k tranquillamente. Naturalmente in 1080pSe il televisore con presa hdmi 2.0 e supporto hdcp 2.2 " vede" , ossia riconosce, un dispositivo senza supporto al hdcp 2.2 ( se non sbaglio l' hdmi 2.0 draft non supportava hdcp 2.2) ti dà un bel no signal. E non potrebbe essere diversamente. Chiaramente sto parlando di contenuti 4k, è chiaro che se mando un segnale hd non fa storie.
"The big difference is that HDMI 2.0 is backward-compatible with previous HDMI versions, while HDCP 2.2 is not backward-compatible when it comes to 4K video. That means you can connect older sources, like a regular Blu-ray player or cable box to a new 4K TV and enjoy an HD picture. But if a 4K TV senses a 4K video source, it's going to look for the HDCP authentication in order to complete the digital handshake. If it doesn't see it, no 4K picture."
Ma tutto ciò è inutile perchè la presa è hdmi 1.4 quindi oltre a non avere l' hdcp 2.2 non ha nemmeno la banda sufficiente: se non per il 4k fino a 30hz di cui ce ne facciamo poco visto che le trasmissioni televisive sono a 60hz.
p.s chiaramente ci possono essere delle eccezioni, ad esempio I Medici, ma si contano sulle dita di una mano.
qualche possessore potrebbe mettere una recensione di pro e contro di questo nuovo neonato
