In Rilievo I satelliti Astra sui 28° E - Spot UK
Un saluto!!!Ricezione stabile a Rapallo(GE)di tutti i tp del 2F(beam UK)con parabola(Gibertini 105cm) puntata sul sat Badr(26°E).:D
A breve,probabilmente,con l'arrivo del 2E dovrò spostare la parabola sui 28.2°E...(sperando che possa bastare).:laughing7:
per quanto riguarda l'1N lo ricevo pure io dal sud del veneto con una penta 85, con segnale abbastanza forte anche con la pioggia...per quanto riguarda il 2F non ricevo nulla ;)
azz .. secondo me non l'hai puntata proprio bene sui 26 .. Io ho differenze tra 26 e 25.5 ho dovuto memorizzare due postazioni differenti altrimenti alcuni trasponder del 25.5 non li vedevo .. figurati con i 28 .. impensabile ..
Conclusa la disputa SES-EUTELSAT
http://www.ses.com/4233325/news/2014/16846982
SES AND EUTELSAT SETTLE THEIR DISPUTE AND CONCLUDE A SERIES OF AGREEMENTS CONCERNING THE 28.5 DEGREES EAST ORBITAL POSITION
Luxembourg/Paris, 30 January, 2014 – SES (NYSE Euronext Paris and Luxembourg Stock Exchange: SESG) and Eutelsat Communications (NYSE Euronext Paris: ETL) announced today that the two companies have concluded a series of agreements including a comprehensive settlement of legal proceedings concerning the right to operate at the 28.5 degrees East orbital position and containing long-term commercial as well as frequency coordination elements.
The first agreement ends the arbitral procedure between Eutelsat and SES that was initiated in October 2012 under the rules of the International Chamber of Commerce (ICC) in Paris. The dispute concerned a right of use of 500 MHz spectrum at the 28.5 degrees East orbital position. Eutelsat ceased to operate this spectrum on 3 October 2013 and SES has operated this spectrum since that date. The dispute over this right of use has now been resolved, with SES continuing to operate its satellites at this location, and Eutelsat independently commercialising part of the capacity of the previously disputed frequencies.
According to the second agreement between both companies, Eutelsat has therefore contracted long-term satellite capacity on the SES satellite fleet at the 28.5 degrees East orbital position. Eutelsat will commercialise over Europe on the SES fleet 125 MHz (eight transponders) of the formerly disputed 500 MHz. Eutelsat will also commercialise on the SES fleet the 250 MHz (12 transponders) which was not the subject of the legal proceedings. The 20 transponders will be operated on three new satellites which SES is deploying at the 28.2/28.5 degrees East neighbourhood – ASTRA 2F, ASTRA 2E and ASTRA 2G – of which the first two have been launched and are operational, while the third is planned for a launch later this year.
quindi Eutelsat 28A sarà spento?? :eusa_think:
le frequenze (20 TP) finiranno su astra 2E, astra 2F e astra 2G ma saranno commercializzate da Eutelsat?
Stando ad un comunicato ufficiale della SES, Astra 2E sarà operativo già da domani.
Beh,no,credo che ci vorranno ancora un po' di giorni di prova....
Penso a meta' mese di febbraio o poco prima/dopo....per ora dal Friuli Occidentale ricezione ok,ma non chiedetemi percentuali di segnale o diametro della parabola perche' non lo so'.
Il 2F, dal Friuli non lo ricevi a meno di usare una parabola dalle misure "importanti", che sapresti benissimo. :D
SES’s ASTRA 2E SATELLITE GOES LIVE at 28.2/28.5 DEGREES EAST OVER EMEA
http://www.ses.com/4233325/news/2014/16858202
Lussemburgo, 31 Gennaio 2014 - SES SA (NYSE Euronext Parigi e Borsa del Lussemburgo: SESG) annuncia che entra il satellite ASTRA 2E in servizio commerciale nell'arco orbitale di 28.2/28.5 ° est il 1 ° febbraio 2014. Il satellite è stato lanciato a bordo di un veicolo di lancio ILS Proton dal cosmodromo di Baikonur in Kazakistan il 30 settembre 2013.
Numerosi test in orbita hanno da allora confermato che il satellite ad essere pienamente operativo e funziona secondo le specifiche.
ASTRA 2E ora è stato implementato alla sua destinazione finale nell'arco orbitale di 28.2/28.5 gradi Est, dove è co-posizionato con ASTRA 2A, ASTRA 2F e ASTRA 1N. Nel corso delle prossime settimane, BSkyB, Channel4, ITV e BBC programmazione in questo arco sarà la transizione al nuovo satellite con la sua potente impronta sulle isole britanniche.
e' che non so' le misute della mia parabola,comunque per ora il segnale c'e' ed e' buono,peraltro,al momento qui sta' piovendo e nessuna pixellisazione,tutto il resto,sul lancio ecc lo sapevo,mi sto' informando costantemente giorno per giorno.
Allora confermo che il 1N si riceve forte e chiaro da torino con una parabola da 80cm.
Ma il 2E si riceve con la parabola nella stessa direzione dell'1N?
Se cosi fosse saremmo "salvi".....io sono molto interessato al bouquet dei free inglesi,perche' tifoso dei 3 leoni di calcio,rosa di Lancaster,quindi rugby,e Wimbledon.
Temo che il beam UK dichiarato ora da 1N, che UK non è, diventerà davvero UK sul 2E. Tale copertura del 2E e poi del 2G coincide esattamente con quella del 2F UK quindi regoliamoci ..
Questa frase è mooolto chiara:
BSkyB, Channel4, ITV and BBC programming in this arc will be transitioned to the new satellite with its powerful footprint over the British Isles
Buongiorno dal Friuli Occidentale.
Ricezione buona anche stamattina,anche se con pixellizzazioni perche' qui piove praticamente in modo ininterrotto da quasi 2 giorni e c'e' vento.
