Avast Free 22.9.6034 (24/09/2022)
@ milanistaavita. Sui forum, scrivono qst versione sia più leggera, :) sia in scansione, sia - e sopratutto questo non è trascurabile - per l'avvio del PC. Quali tue prime impressioni?
P.S. Visto che hai aggiornato dalla stessa GUI della precedente versione, ricordi se, all'aggiornamento, faceva tutto lui, di sua iniziativa, oppure ti consentiva di scegliere fra installazione express o personalizzata? :eusa_think:
Scusate io ancora non ho aggiornato ma se apro avast mi segnala la versione 9.0.1500 e non quella indicata nel titolo del 3d.
C'è qualcosa che non va?
Versione 9.0.2006
15/10/2013
New DeepScreen technology allows avast! to make more intelligent decisions about new/unknown files
New Hardened mode for stricter lockdown scenarios
Improved cloud scanning features and crowdsourced analysis of suspicious items
Continuously streaming update (CSU) technology for up-to-minute detections
Improved cleaning of malware
All-new web browser plugins featuring comprehensive security ratings, protection against malware, phishing and typosquatting sites and Do-Not-Track (DNT) functionality for improved anonymity on the Internet
All-new SafeZone for more secure online shopping and banking
Rescue disk - allow users to create a bootable CD or flash disk with Avast on it
A new, streamlined user interface for simplified navigation and more user comfort
Control and manage all protected devices directly from the Avast console (through integrated the avast! Account)
Dramatic reduction in product size and memory footprint
Faster scanning thanks to optimized scanning engine
Completely rewritten setup/updater that makes the installation and upgrade process faster, easier and more reliable
Firewall has been redesigned from scratch to allow for better compatibility with latest Windows, better performance and full support for IPv6
Network protection component tuning & compatibility (WFP technology on Win8+)
Various improvement in the Software Updater and Browser Cleanup tool
Full Windows 8.1 compatibility
Improved general AV performance and stability, including security fixes
Aggiornato, due messaggi nel centro manutenzione vediamo se impostando manualmente avast e riavviandolo lo prende...
Ho letto nel forum ufficiale diverse persone che lamentano problemi e mi sono documentata su questa versione.
Per ora non mi piace affatto. Hanno anche ridotto le protezioni in tempo reale limitandole a quelle dei file di sistema, web e quella per le mail.
In più, gli aggiornamenti in streaming dovrebbero partire ogni minuto?
Per ora, mi tengo stretta la versione precedente. Poi si vedrà.
Tanto basta che si aggiornino le firme virali e gli aggiornamenti in streaming e non dovrei avere problemi per il momento.
Versione 9.0.2006
15/10/2013
Ercolino quindi secondo te anche se in manutenzione segnala la versione 9.0.1500 in realtà poi viene installata la 9.0.2006?
In ogni caso per aggiornare conviene rimuovere prima la vecchia oppure fa tutto in automatico?
Disponibile Avast 9.0.2006 versione 2014
tramite stesso av ho aggiornato (...) alla ... 9.0.2006
No... forse un bug della vecchia 8.0.14xx, la sua Grafic User Interface, infatti, ieri mi diceva altrettanto:
:eusa_think: Come nuova, a me da (la GUI della attuale 8.0.1497) disponibile 9.0.1500.
Quando però ho disinstallato la 8.0.1497 e installato l'ultima, scaricata dal sito di avast!, ho ottenuto proprio la 9.0.2006. ;)
penso che non mi funzionino i pop up di notifica .. controllate anche voi grazie.
matteo90 ha scritto:
installato stamattna, nessun problema... Escono i messaggi come prima...
Anch'io installato da poco (disinstallata però prima vecchia 8.0.1497), ed i pop-up escono :happy3: come sempre (stavolta, invito all'upgrade anziché quello "classico" verde)
Gia' controllato ieri .. tutto a posto.
Prova ad attendere che sistemi da solo... magari al prossimo aggiornamento si "stabilizza" tutto.
Al limite, prova a disinstallare con l'uninstaller ufficiale e a reinstallare di nuovo la 9.0.2006. ;)
Mah, io l'ho aggiornato tanto per vedere. Dopodomani si formatta e chissà se la reinstallerò...
Intanto ho gradito l'alleggerimento generale la nuova UI e il fatto che non mi blocchi più gli script di digital-forum (eh capirai hanno tolto l'analisi in tempo reale...)
leggera in che senso?? io mica ci debbo fare chissà che cosa, ho solo aggiornato e sarà lui (avast) a ricamare sottotraccia :D
ora che ci penso però, accendendo il pc perde qualche secondo in più di prima, non so se dovuto a avast... :eusa_think:
ho solo dato la scelta FREE, per il resto ha fatto tutto lui perdendo diversi minuti :wink:
io aggiornerei direttamente dalla manutenzione senza procedere ad alcuna disinstallazione della precedente versione; è previsto e non vedo quali rischi si possano correre; o no ercolino? ;)
giollo63 pure io la penso come te.
In genere ho sempre aggiornato così. Al momento però non ho ancora aggiornato.
Come vianello me la prendo con molta calma :D
i popup di rilevamento\stato aggiornamenti sono peggiorati con la nuova GUI prima erano piu efficaci,tutto su sfondo colorato pieno(rosso\verde\arancio)ora ci sono bande colorate su sfondo bianco e scritta nera!
la gui in generale in stile WIn8 mi pare piu leggera(anche perchè non c è niente ed è decisamente scarna) ma piu confusionaria x certi aspetti!
Tutto OK fratello,vai tranquillo che con noi sei al sicuro:)
lo promuovo con riserva rispetto alla precedente versione!
