E' uscito ALT- DVB 2.1 !!
Nighteagle
Digital-Forum Gold Master
11 Febbraio 2002
Planet Earth
E' uscito ALT- DVB 2.1 !! (Sostituito da 2.2)
A prima vista sembra un ottimo lavoro....a domani commenti più dettagliati:D
Grazie, lo provo subito :icon_wink:
Ecco le novità:
AltDVB 2.0
# New hardware interfaces:
* Pinnacle PCTV Sat (no CI version)
Thanks to: MPatrascanu
* NovaPCI
Thanks to: Stailus
* Twinhan VisionPlus (tested only with VP1020a)
Thanks to: Rahaal & Neztiti
* Network Client
Full control of DVB card + TS streaming over TCP/IP
Server (AltSRV.exe) must be running on remote PC !
# Application:
* Minimize to tray
* Mouse gestures (on video & teletext window)
* Video: Stay-On-Top Floating Windows (magnetic to screen borders)
* Scheduler, with "Wakeup-from-Standby" option (hardware dependent)
* Software decoding using FFDeCSA (ported from linux)
* Direct shortcuts for scanning current transponder/current satellite
* Sleeptimer, with exit/suspend/hibernate/shutdown option when time elapsed
* Command line parameters (see CmdLine.txt for details)
* History graphs for signal,CPU & Memory
* Extended keyboard shortcuts & RemoteControl
* Multiple favorites per channel (max 4)
* Improved channels group/filter
* Operations on selected channels: Delete All,Set Favorites,Set PluginProfile
* USALS GotoX angle adjusted with your location (thanks to Ulrich B. [DF6JB] )
* Transport Stream information (PID DataRate & DataType)
# DirectShow:
* New source filter with internal A/V demuxer
* Automatic graph builder (by selecting filters)
* Configuration form .GRF/.XGR or .GRS (Graph Script)
* Manual aspect ratio settings (Letterbox,4/3,16/9)
* Overscan border in full-screen (optional)
* Color setting in VMR9 Mode (hardware dependent)
* Audio channel A/B selector (MonoSwitch.ax)
* Audio/Video MediaType detection
* Can play AC3 stream
# Interfaces:
* Dynamic HW/SW PID filters for SkyStar2
* Software mode for SkyStar1
* Record for SkyStar1 (PVA format only)
# Plugins:
* Enhanced management
* User profiles (enable/disable group of plugins)
* Profile can be automatically changed on new channel
* Can deliver TS packets (188bytes) if PID |= 0x8000
# Scanner:
* Transponders: List editor
* Transponders: Synchronize & Update (from WWW or SDX or NIT or other INI file)
* Transponders: Selections using multiple condition (Freq Range,SR Range,Polarity)
* Channels with no service description (SDT) can be auto-updated from SDX file
# Record:
* Stop conditions (Size/Time) & configurable split size
* Custom filename format
* Full Transport Stream Recorder (DVB Card dependent)
* Single PID recorder
# Services:
* EPG Viewer with content and text filter/search
* Teletext subtitles (software mode)
* Native teletext (unicode) with hotlink navigation (page numbers & web addresses)
# Fixed:
* Recording OK when using FFDecsa
* Channel/Group sorting bug
* DiseqC commands for simple switches (Toneburst A/B)
sembra davvero bello... anche i canali in HD mi vanno da subito fluidissimi....:D
L'ho scaricato ma appena lo aro non visualizzo alcun canale e mi da l'errore:
AV0: Graph error [5001]
No graph file (GRF/XGRGRS).
Please configure DirectShow!
Come devo procedere con le configurazioni?
Ho una skystar 2.
Grazie.
devi installare il grafico del filtro che vuoi utilizzare da setting -> video direct/show, in alternativa li torvi già fatti sul sito scaistar...ciao
Eccoli qua!
Un grazie a SCAISTAR per la creazione.
I migliori sono i Dscaler, OK anche sugli HD :icon_wink:
Scusatemi tanto ma non sono ancora riuscito a impostare correttamente il programma, ho scompattato il file zip all'interno della cartella graph di Alt-Dvb, sono andato nella finestra setting>video/direct show dove nella sottofinestra DVB-Main mi compare un menu a tendina nel quale sono presenti vari filtri, per quanto riguarda i Dscaler me ne appaiono 3, selezionandone uno alla volta mi appare sempre il messaggio di errore Graph not loaded mentre se clicco si Check graph filter mi da per il dscaler 2 messaggi scritti in rosso con class not registered.
Mi potete spiegare un po' più dettagliatamente la configurazione corretta?
Grazie.
Grazie.
una volta che sei arrivato al sottomenù DVB-main nel centro della finestra ci sono due pulsanti automatic e graph file,seleziona quest'ultimo e poi scegli il filtro che preferisci da quelli che hai scaricato...ciao p.s se hai problemi fai un fischio:icon_wink:
Purtroppo il fischio lo devo fare:eusa_whistle:
Se faccio come dici tu, arrivo a selezionare il filtro ma facendo il check mi da l'errore che dicevo prima (class not registered) e in cima alla finestra mi appare sempre il messaggio graph not loaded.
:eusa_wall:
Preleva i graph dal sito scaistar e mettili nella corrispondente cartella di altdvb, poi seleziona una combinazione che ti funziona nel directshow main e anche nel pip
Vi dico passo passo quello che ho fatto:
Ho scaricato il file zip di alt-dvb e l'altro zip per la skystar 2, ho preso lo zip contenente i filtri dal sito scaistar e l'ho scompattato nella cartella graph di alt-dvb, ho lanciato il programma e sono andato nella sezione setting>video/direct show, nel menu dvb main vado a selezionare manualmente il filtro desiderato ma quando salvo ed applico mi compaiono i messaggi di errore che vi ho detto prima.
Dove ho sbagliato?
Per far funzionare i graph Dscaler devi comunque avere i Dscaler installati sul tuo PC.
Idem per Nvidia,Intervideo,ecc :icon_wink:
Ho provato tutti i filtri che mi visualizza e nessuno di questi mi funziona correttamente. Non so più che fare.....
Sono riuscito a risolvere, ho scoperto che dopo un rispristino del pc che ho fatto qualche giorno fa mi erano scomparsi i filtri dscaler installati, li ho scaricati nuovamente ed ora funziona tutto....
Grazie nuovamente!
tutto bello ma non riesco a spostare il disco va dove ne ha voglia lui ho settato in positioner la long e lat ma irisultati sono deludenti ( il vecchio alt dvb va ancora a meraviglia sui vari sat ) se potete dare qualche dritta
in auto si deve usare l'icona tool e settare il diseqc oppure si deve usare come nel vecchio l'icona scan e vari settaggi
non ci capisco un tubazzo
grazie
