Per curiosità posto alcuni dati tecnici di Rai Premium HD (che anche quest'anno non riesce a trasmettere in 5.1 la replica del festival di sanremo...
[Elenco filtri usati]
(1) Built-in MPEG2 TS Source
(2) Built-in Video Codec/Transform
(3) Enhanced Video Renderer(Custom Present)
(4) Built-in Audio Codec/Transform
(5) DirectSound Audio Renderer
[Informazioni video]
Codec: H264 - Decoder FFmpeg interno(h264, Thread Frame)
Tipo di input: H264(24 bits)
Dimensioni input: 1920 × 1080(1.78:1)
Tipo di output: NV12(12 bits)
Dimensioni output: 1920 × 1080(1.78:1)
Frequenza fotogrammi: 25
BitRate: Sconosciuto
[Informazioni audio]
Codec: Dolby AC3(0x2000) - Decoder FFmpeg interno(ac3)
Frequenza di campionamento: 48000 ->48000 campionamenti/sec
Bitrate: 0 ->32 bit/campionamento
Canali: 2 ->2 canali
Bitrate: 448 kbps
General
Complete name : D:\Records\Rai Premium HD @164426_10FEB2024\Rai Premium HD @164426_10FEB2024.000.ts
Format : MPEG-TS
Format profile : No PAT/PMT
File size : 3.91 GiB
Duration : 1 h 20 min
Overall bit rate : 6 909 kb/s
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference fra : 2 frames
Bit rate : 6 115 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Scan type, store method : Interleaved fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.118
Stream size : 3.46 GiB (88%)
Color range : Limited
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : -675 ms
Stream size : 259 MiB (6%)
Service kind : Complete Main
Poi ci sono Rai 1 HD (DTT) e Rai 1 HD (SAT):
Canali: 2 ->6 canali
Bitrate: 384 kbps
General
Complete name : D:\_MSTPVR\20240210_003043_[1 Rai 1 HD]_[74° Festival della Canzone Italiana].ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 215 MiB
Duration : 3 min 23 s
Start time : UTC 2024-02-09 23:30:55
End time : UTC 2024-02-09 23:33:55
Overall bit rate mode : Variable
Overall bit rate : 8 871 kb/s
Network name : Rai
Country : ITA
Timezone : +01:00:00
FileExtension_Invalid : m2ts mts ssif
Video
Menu ID : 1101 (0x44D)
Format : AVC
Codec ID : 27
Duration : 3 min 22 s
Bit rate : 7 733 kb/s
Color space : YUV
Bit depth : 8 bits
Scan type : MBAFF
Scan type, store method : Separated fields
Bits/(Pixel*Frame) : 0.149
Stream size : 187 MiB (87%)
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Bit rate : 192 kb/s
Frame rate : 41.667 FPS (1152 SPF)
Delay relative to video : -365 ms
Stream size : 4.64 MiB (2%)
Language : Italian
Audio #2
Format : AC-3
Codec ID : 6
Bit rate : 384 kb/s
Delay relative to video : -580 ms
Stream size : 9.30 MiB (4%)
Language : oth
Audio #3
Format : MPEG Audio
Codec ID : 3
Bit rate : 64.0 kb/s
Channel(s) : 1 channel
Delay relative to video : -269 ms
Stream size : 1.55 MiB (1%)
Language : oth
Audio #4
Format : MPEG Audio
Codec ID : 3
Bit rate : 128 kb/s
Delay relative to video : -533 ms
Stream size : 3.10 MiB (1%)
Language : English
e qui la versione SAT
Canali: 6 ->6 canali
Bitrate: 384 kbps
General
Complete name : D:\PVRRECORD\Rai 1 HD-09022024-2354.pvr\data0001.ts
Format : BDAV
File size : 372 MiB
Duration : 4 min 11 s
Overall bit rate : 12.4 Mb/s
Video
Menu ID : 3401 (0xD49)
Format : AVC
Format settings : CABAC / 3 Ref Frames
Format settings, Reference fra : 3 frames
Format settings, GOP : M=4, N=16
Codec ID : 27
Bit rate : 11.1 Mb/s
Color space : YUV
Bit depth : 8 bits
Scan type : MBAFF
Bits/(Pixel*Frame) : 0.213
Stream size : 331 MiB (89%)
Audio #1
Format : MPEG Audio
Codec ID : 3
Bit rate : 192 kb/s
Delay relative to video : -853 ms
Stream size : 5.75 MiB (2%)
Language : Italian
Audio #2
Format : AC-3
Codec ID : 6
Bit rate : 384 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Delay relative to video : -833 ms
Stream size : 11.5 MiB (3%)
Language : oth
Audio #3
Format : MPEG Audio
Codec ID : 3
Bit rate : 192 kb/s
Language : English
Audio #4
Format : MPEG Audio
Codec ID : 3
Stream size : 1.92 MiB (1%)
Language : oth
Text #1
ID : 567 (0x237)-777
Format : Teletext Subtitle
Language : Italian
Text #2
ID : 567 (0x237)-778
Language : English
Other
ID : 567 (0x237)-100
Format : Teletext
Language : Italian
Menu
List : 501 (0x1F5) (AVC) / 601 (0x259) (MPEG Audio, Italian) / 611 (0x263) (AC-3, oth) / 621 (0x26D) (MPEG Audio, English) / 631 (0x277) (MPEG Audio, oth) / 567 (0x237)-100 (Teletext, it) / 567 (0x237)-777 (Teletext Subtitle, it) / 567 (0x237)-778 (Teletext Subtitle, en) / 2012 (0x7DC) () / 3012 (0xBC4) () / 3101 (0xC1D) ()
Language : / Italian / oth / English / oth / Italian / Italian / English
Infine arriviamo a Rai 4K...
SAT:
Codec: HEVC - Native D3D9 DXVA Decoder(VLD) - AMD Radeon(TM) Graphics
Tipo di input: HEVC(24 bits)
Dimensioni input: 3840 × 2160(1.78:1)
Tipo di output: dxva
Dimensioni output: 3840 × 2160(1.78:1)
Frequenza fotogrammi: 50
Bitrate: 384 kbps
General
Complete name : D:\PVRS\Rai 4K-2024-02-06 22-23-15.ts
Format : MPEG-TS
File size : 379 MiB
Duration : 2 min 35 s
Overall bit rate : 20.5 Mb/s
Video
Menu ID : 3407 (0xD4F)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main
10@L5.1@Main
Codec ID : 36
Duration : 19 h 18 min
Width : 3 840 pixels
Height : 2 160 pixels
Frame rate : 50.000 FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Encryption : Encrypted
Color primaries : BT.2020
Transfer characteristics : HLG / BT.2020 (10-bit)
Matrix coefficients : BT.2020 non-constant
Audio #1
Format : AC-3
Codec ID : 6
Duration : 2 min 34 s
Bit rate : 384 kb/s
Delay relative to video : -592 ms
Stream size : 7.09 MiB (2%)
Language : Italian
Audio #2
Format : E-AC-3
Format/Info : Enhanced AC-3
Codec ID : 6
Channel(s) : 3+ channels
Language : English
Menu
List : 507 (0x1FB) (HEVC) / 607 (0x25F) (AC-3, Italian) / 617 (0x269) (E-AC-3, English) / 2012 (0x7DC) () / 3012 (0xBC4) () / 3101 (0xC1D) ()
Language : / Italian / English
Service name : Rai 4K
Service provider : Rai
Service type : reserved for future use
HbbTV:
General
Complete name : ...
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (mp41/avc1)
File size : 190 MiB
Duration : 2 min 36 s
Overall bit rate : 10.2 Mb/s
Encoded date : UTC 2024-02-09 19:51:47
Tagged date : UTC 2024-02-09 19:51:47
Writing application : vlc...
Comment : QuickTime 6.0 or greater
Video
Format : HEVC
10@L5.1@Main
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 10.0 Mb/s
Frame rate mode : Constant
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.024
Stream size : 184 MiB (97%)
Language : English
Codec configuration box : hvcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Variable
Bit rate : 317 kb/s
Maximum bit rate : 437 kb/s
Frame rate : 46.875 FPS (1024 SPF)
Stream size : 5.92 MiB (3%)
Language : English
