In Rilievo Plugin for enigma2 - ChocholousekPicons updater (include DTT Italia)
chocholousek
23 Marzo 2020
Czech - Moravia
Chocholousek picons - plugin for updating Chocholousek's picons in Enigma2 (all EU satellites)
The original intent for developing this plugin was to save free space on the device's internal disk. The plugin downloads a series of file archives (7-zip) with picons, for user-selected satellite positions. From the archives, the plugin unpacks only the necessary picons to the internal disk (depending on the service reference codes found in the "userboquet" files).
In the new version of the plugin you can choose the method of updating the picons:
Copy all picons: Delete all current picons as first
Copy all picons: Incremental update (copy only new picons or picons with different file size)
Sync with TV channel lists (userbouquet files)
Sync with TV+RADIO channel lists (userbouquet files)
If the 7-zip archiver is not found on the system, it will be attempted to install it in two steps:
with package manager (i.e. attempt to install 7-zip from your Enigma feed server)
or attempt to download a standalone 7za binary file from internet
Functionality is guaranteed and tested on Enigmas based on the following OE cores:
OpenATV, OpenPLi, VTi, PurE2 - based on OE Alliance 4.x or OE 2.0
OpenDreambox, Merlin, DreamElite, Satlodge (1.3b) - based on OE 2.5 and higher
Unfortunately, not all picon styles exist for all resolutions or vice versa - not all resolutions exist for every picon style (background). All picon styles are available only in picon resolution 220x132 (which can be considered the most used).Chocholousek picons - plugin for updating Chocholousek's picons in Enigma2 (all EU satellites)
PLUGIN DEVELOPER : s3n0
PICON DESIGNER : chocholousek
DOWNLOAD (IPK / DEB) : https://github.com/s3n0/e2plugins/tree/master/ChocholousekPicons/released_build
SOURCE CODE : https://github.com/s3n0/e2plugins/tree/master/ChocholousekPicons/
CHANGELOG : https://github.com/s3n0/e2plugins/blob/master/ChocholousekPicons/src/changelog.txt
YP6KN9OWdABfUEsRV_NWqs9PAbtY1FVI2MVLVH2jir0lmRbhACF7E-ZpVkGQ4iWzJxXHrJeMOINl_WJXdDM2pKIrP05UQFHuonPamLTYsUj5knNypjv9oD_jPA082V7_MtE_xO-zgpGP3jhYeSyAxPXzgHjhOei__K9ngtNFTs0ljQqPf43k7vv613G_kLR1kgLDDoeyXIvqFuzab5zw25HkAHP9-5Rh6Ovg_29cAFxGNLwXXe-GgBM0yvv_DQbhPwQRKSkbRYYArcOyunPEaXKSlp6RxxRUxHzn5sfWpytDE0eMNsPHjyhO2U1vF9eKTUeiTzXueqd8JYsBKcvsnnxmblHGIiPPUbtlWFQ0QGeSI-woEWE11GpmPJIzHuUV4iWTSSOy7ZfhlVggFmuUzsl9SPJCOORFGwyZXoz_iFQYqwTQKQdFm3HzJ9p29R0DbFsdquXpfh0XCu9EJkvlygwC3XKDVwa_Pphucm0GFHuqBlO1FK0LhaREWBERGPNxUpfgQOjdSpr7T75Bxv_z0ruSL_N9bCLVxcvJclJaZJUJ-dnoIpBSB1r1v7hE-KO9Pe4mzfF3puVv6Hd2jnz7npsG8YP8Jylm9xzM2QOCEcV1yBMCJ8FLip7wJawxJWuUbNWS1OmKmSh9YStg27h756Ld1-CvEYNkDOPCazUbC7J4afd29C-d8wwJ_249soaUQHzwp9DMUqznVcpgZPLzmw_4kvvTIE5m_1-aztzZV6ipXEqNCTK-M-U=w640-h375-no
XiO2fs6-KHpHT0L36fQZsBwzdi5pZ8eLIADKwYnY4Cl8x4mgsGDZpP_jFkRFmsbShXOCegpOig8i-0z_fS1UngT8dQ-LPLNTxIckTHzv9m7Hx8UTmKQ3OLu3MKNdMO9dTeIU8_bal0V-Ck0OSd41q8H8InBQShROXSX_Rf58lMeL1NiUV2Y4uUe8FDTDeu2A6rXPmqYdzAhIVSxBaHX8HyFtD8p003bufkr4cMU-U4B3X1fwdMzHlQ8e8Ftwv-zhqQfsXG4HExeSBRaXFGV9g-grjOTIvXDJoW9Fw414E32EtNv741HZkwfIpzLAy6SCpuRfi8MYbNpPP1aG3_-N1Tv-LuxrIsW07OLYUoS7mxhiF1LcrXotLrWBVyAKcYV83_uQVGUMFGnJQ-25wdgTxqxxxT56OSGsOR9d70Mzb_0TVj-K7QIUjot1VkHEplwzuOb0M-IZdHoLcSPlOwJI6edI2Fmhg1vJZyH3u9wF94ueTbduR7CvuXuuX6NDYqJrY8APkqp152z4pBFPa5Vd75nkeEmDi811YFxNR99YI8_rj2h0iScAQb1pp6QaqLGnE8Ir3H8ofz2L4Nq6OfvvqB6hjcdfK8D-dSF_6pb7y0jO9E1d6kw_9odmz9ndKLvoZu_qNut4BvswZbVvSRq3gkWg8AxSn8rckccmf7yG--aMPhaR132fY5dLw_Q6NZry_mnd7DBfdKHfUgsUH0s1fQ_ss8t1fPo2kDmHO_MzhnfxFWvUQvAh1a4=w640-h375-no
Picons SAT e DTT Italia - All chocholousek picon packages
io ho scaricato l'updater, ma non ho capito se comunque di base devo scaricare nel ricevitore anche i picons, perchè mi da ok sulla connessionme internet ma poi mi da un errore di aggiornamento, su dreamelite
Picons Chocholousek - plugin per l'aggiornamento dei picons di Chocholousek in Enigma2 (tutti i satelliti dell'UE)
L'intento originale per lo sviluppo di questo plugin era di risparmiare spazio libero sul disco interno del dispositivo.
Il plug-in scarica una serie di archivi di file (7-zip) con picons, per le posizioni satellitari selezionate dall'utente.
Dagli archivi, il plugin decomprime solo i picon necessari sul disco interno (a seconda dei codici di riferimento del servizio trovati nei file "userboquet").
Nella nuova versione del plugin puoi scegliere il metodo di aggiornamento dei picon:
Copia tutti i picon: elimina tutti i picon correnti come primo
Copia tutti i picons: aggiornamento incrementale (copia solo nuovi picon o picon con dimensioni file diverse)
Sincronizzazione con elenchi di canali TV (file userbouquet)
Sincronizzazione con elenchi di canali TV + RADIO (file userbouquet)
Se l'archiviatore a 7 zip non viene trovato sul sistema, verrà tentato di installarlo in due passaggi:
con gestore di pacchetti (ovvero tentativo di installare 7-zip dal server di feed Enigma) o provare a scaricare un file binario 7za autonomo da Internet
La funzionalità è garantita e testata su Enigmas in base ai seguenti core OE:
OpenATV, OpenPLi, VTi, PurE2 - basato su OE Alliance 4.xo OE 2.0
OpenDreambox, Merlin, DreamElite - basato su OE 2.5 e versioni successive
Sfortunatamente, non tutti gli stili di picon esistono per tutte le risoluzioni o viceversa, non tutte le risoluzioni esistono per ogni stile di picon (sfondo).
Tutti gli stili di picon sono disponibili solo con risoluzione picon 220x132 (che può essere considerata la più utilizzata).
Picons Chacholousek - plugin per l'aggiornamento dei picons di Chocholousek in Enigma2 (tutti i satelliti dell'UE)
Spero la traduzione sia utile, complimenti a Chocholousek davvero ben fatto e molto utile.
Please describe the error in more detail, if the greenscreen send crash log.
this is a section package not a updater section
The problem is related to the location chosen for the picons, I have been warned that the folder picons doesn't exist, so I tried to create one into the internal memory but with no success, so I moved to the hard drive, I have created one into it and the procedure went on until the end, in the end when I go to check these picons, after rebooting, I have no picons for the dtt channels, I have just the old ones download through a procedure from the dreamlite blu panel. Maybe it's my fault zone I'm not familiar with this kind of precedure, maybe you could give us a guide for the precedure. Maybe it's related to the skin that I use?
Yes the folder where the picons are located needs to be set. Depending on the image or skin used. Plagin has only the most common paths used or set user-defined.
Note that this may be related to the update method set.
If you set up sync, it must be 100% match.
If it does not display the logo.
Service references can be different, depending on the device used or satellites.xml (terrestrial.xml) .100% assurance only with Vhannibal sentigs. :)
per dreamelite scegli come picon folder data/picon e suggerisco di optare per la cancellazione dei picon giá presenti
ovviamente da menu configurazioni/sistema/personalizzare scorri fino a scegliere percorso picon /data
vale stesso discorso se preferisci usr/enigma2/picon ci deve essere corrispondenza tra folder del plugin e percorso nelle impostazioni questo credo lo sai
peró qui si parla di packages non del plugin io sposterei tutto
Complimenti a chocholousek per l'ottimo lavoro svolto e a maumixio per la collaborazione. ;)
2.1.200427
- A directory browser has been added - for the purpose of selecting a user-defined picon folder.
- !!! please be careful when deleting and creating folders in the directory browser !
- !!! you are responsible for any loss of important data, after accidentally deleting the directory !
- Minor changes in the source code.
wv_ywklnsVxqMEIqm-hHDWnrPXamzvrc7S5kZYWfjo9FsCzK9Kan2_ITuUMyESpjx6C5h93oCkQZg9eExIXI5jmHf-EWN7IwXV-tTUF64SFTmVUxUgqH8aRXeoclvGYCwfrgfTklCYCf7oADlOV-QRsjNx1pzPI02IT7uqF1Vx5LYb-b4F82jT0ULDZFMplsDtNIzoOrIXBRFTT1nGZgKwN8tU-cwCmEbrCDqEu3OS2j4BBpR1FKkPBWo-wV923XsQOjpKRO3Rk5NEUeafy91ZgoLmHTybFlRcQiltzZ62IRQyCgXWL0aRnwXU_PgATYcYueJZRXy9pdJwPLBKdzfZDywh-XgRnKQ7Trg-du6XcnX84LQe9SVc9rfKpxyqGcfCyJuGt1Zq8isJpmKUSeZVKXDa3EHN4bvK2QpUll-uYWWELOj749DqEKJcx1caLE1cO3AtmhtZKeTFcGG1dzybzkA3QAdJnG4dXaPkXqwatuGzrcgt1q9-Nf0jzqOb2QUh8y9xX32WzIsJQcYKRGZqa77sPiACY5y7yyHLE6K1Vy5Onp26O-S-T9PXBDgPVIAIu5RDGKLS_8d-vumLwza2Y2BP2BtHiLLlj1b6m9OOaR1PyZ7Wbh7K1i-86HA7r0cvy7aWHG_PSSvnfV-Fged6PppYFVzkreBTGD0dZgoI6-j5VrHQTLXHQym-r10N7fkfNIYFw1Wym8JBwkZOdtI3V7pUw0RpCJ-b9yh6K8VkN6XGliKeL-Ps4=w560-h782-no
2.1.200427
https://github.com/s3n0/e2plugins/r...nsions-chocholousek-picons_2.1.200427_all.deb
https://github.com/s3n0/e2plugins/r...nsions-chocholousek-picons_2.1.200427_all.ipk
È stato aggiunto un browser di directory - allo scopo di selezionare una cartella picon definita dall'utente.
- !!! fai attenzione quando elimini e crei cartelle nel browser delle directory!
- !!! sei responsabile per qualsiasi perdita di dati importanti, dopo aver cancellato accidentalmente la directory!
- Modifiche minori nel codice sorgente.
Sorry, if I understood correctly.
Goto "Picon folder", select "user defined" and goto user defined folder line click "OK", now new menu directory browser.
Ii7bIH7lflCnzYJp2i4TS10gTsMWPaNeJxD-vLKfv7F2uT8BmvuwNGDkBMP48gWVeY5_OqFsKZO1xTa3l6JtU1SrXo0rqIYKXiH5JXDyvfTeh6zSUWiA1ErkiZxaKY90cIvBQGeobZNVrm_FXnl0mgmRnZwCcY_mjv7WkGRSJNy0FPEsigtpAC23stfPBM1RoOe6nAn-I2YjtZjgI1N-vdwZpbgQaaL_XfkRuj_n6xkr43ZTievw4A7es8Q74jN4egVaDGpPFiQ0oWz_6hFAxjWxmw_HT4TJI3fhvgCLr50ZrDiCXAcG9Dpw2nMLz-nGAKnhDToY0TqEQwJayOx82V9fO1aDiL5kYkdvDH929LKHTB1EtKOUeV9Htcaot-RVvkFRtUv4-WD3xyoOQhjPzsZKf-KscfiYiJzFXO0TAGVO47E4cu0E74ScONgzRgisks-CiNILjW-HiaNTAPPcwVcbRcQqM6sevdBawLgTxcDWHHlM0Ts5CD5pN2JZm1-QYlijM28q-CnMiy9TIMtPKat0E7eUCRWCCV2iVIFOma1d2Wsp6sP9lm6n-tHhlyh-4cy5fwMewZ0GHfq-qbLfJj01sJRziXRXDdFWQ6RGOwKYCVI6rEPJAH1ZrrEtKPawR6UZCfzUeF0sTFgWrqXAH-aXJOhKVDMdmjmaoUqjX44VBboVQ2xjSlYO5AGSKqEuuZ5vAHutbfJoTa137_Gj-lnETyeP49p207MylPDU0Im_HDz-3jFkKmo=w600-no
puoi aggiornae il primo post perchè è pienamente compatibile e funzionante in tutto con la immagine Satlodge 1.3b :thumbsup:
Attention, plagin Chocholousek picon updater in version v2 and older, gradually losing various backgrounds and the picon package. Gradually, it will not be possible to download anything. It will occur after October 2, 2020 when the last picon update will be on g-drive and these will remain out of date until October 30, 2020, then it will not be possible to help version v2 and older plugin download anything. This is related to the gradual departure of the picon package with g-drive, and these continue to remain and are only updated on the new storage. There is still and will be a fully functional download of picon only in version v3 and newer plugin Chocholousek picon updater, which supports the new picon repository.
