Cambio centralina 6 famiglie: da Offel CF40 28-125 a Televes MiniKomF 562401
Quindi un tv che rispetta queste direttive quando segna 100% e perché sta rilevando un segnale compreso tra 55dBuV a 65dBuV?
Considerata l'incertezza di +-7dB + 3 dB di quella relativa. 50dBuV>70dBuV
Io direi che sarebbe il caso di studiare le Nordig Requirements che indicano ai produttori come deve interagire l'indicazione di segnale rispetto al segnale di ingresso:
3.4.4.6 Requirements for the signal strength indicator (SSI)
The terrestrial NorDig IRD shall be provided with a signal strength indicator (SSI). The value for the SSI shall be referred to the IRD RF signal input.
The terrestrial NorDig IRD shall be able to determine signal strength within a range starting from 15 dB lower than the reference signal level defined in Table 3.6 and up to 35dB above that value or maximum signal input level defined in section 3.4.10.5.
The absolute accuracy shall be ±5 dB at RF signal input levels -80 dBm to -60 dBm and ±7 dB for RF signal input levels higher than -60 dBm.
The relative accuracy should be ±3 dB between centre frequencies within one frequency band, e.g. VHF Band III or UHF Band IV/V, supported by the receiver.
The signal strength indicator shall have a relative value within a range from 0% to 100% and with a resolution of 1%. The signal strength indicator shall be updated regularly once per second.
The formulas to calculate the signal strength indicator (SSI) value in [%] are defined below.
See also Annex E: Implementation Guidelines for best service selection in automatic channel search
SSI = 0 if Prel < -15dB
SSI = (2/3) * (Prel + 15) if -15 dB ≤ Prel < 0dB
SSI = 4 * Prel + 10 if 0 dB ≤ Prel < 20 dB
SSI = (2/3) * (Prel - 20) + 90 if 20 dB ≤ Prel < 35 dB
SSI = 100 if Prel ≥ 35 dB
where
Prel = Prec - Pref
Prec is referred to signal level expressed in [dBm] at receiver RF signal input.
Pref is reference signal level value expressed in [dBm] specified in Table 3.6 for DVB-T and in
Table 3.7for DVB-T2.
La prima release delle Nordig Requirements risalgono a maggio 1998 e Nella NorDig partecipano come associati o partner i principali produttori di ricevitori TV tra i quali:
ASSOCIATED:
Philips
https://www.philips.com
Vestel
http://www.vestel.com/
PARTNERS:
C More
http://www.cmore.se/
Digital TV Labs
http://www.eurofins-digitaltesting.com/
Dolby
http://www.dolby.com/us/en/index.html
Fraunhofer
http://www.fraunhofer.de/
June
http://www.june.se/
Levira
http://www.levira.ee/en/
LG
http://www.lg.com/dk
MTV
http://www.musictelevision.fi/
Panasonic
http://www.panasonic.eu/
Samsung
http://www.samsung.com
Silema
http://www.silema.se/
Sofiadigital
https://sofiadigital.com/
Sony
http://www.sony.com/
TPVision
http://www.tpvision.com/
Viaplay
http://viaplay.se/
Guarda, a me di tutte le tue norme in tutte le lingue possibili e immaginabili importa ZERO. Ho riparato per 30 anni ogni tipo di televisore, videoregistratore, decoder e quant' altro e ti posso garantire che NON C'È un cag che agisca in modo identico all' altro. Spesso scambi la teoria con la pratica, e non è la stessa cosa. Giusto per fare un esempio, la gestione delle cam nei televisori. Ci sono montagne di documenti in merito, ma poi ti scontri con incompatibilità insormontabili. E d' altronde se fosse così facile, qualunque apparecchio sarebbe equivalente. Mai stato così. Tanti tv Samsung ricevono e agganciano perfettamente a meno di 30 dBuV, siamo ben fuori dalle linee guida. E aumentando il segnale, si piazzano al 100% molto presto, cosa che altri apparecchi fanno molto dopo.
Puoi Mettere anche 10000 link, la realtà è questa..
Guarda, a me di tutte le tue norme in tutte le lingue possibili e immaginabili importa ZERO. Ho riparato per 30 anni ogni tipo di televisore, videoregistratore, decoder e quant' altro e ti posso garantire che NON C'È un cag che agisca in modo identico all' altro.Tanti tv Samsung ricevono e agganciano perfettamente a meno di 30 dBuV, siamo ben fuori dalle linee guida.
Onore alla tua trentennale esperienza...
Riguardo la linea guida alla quale i produttori di ricevitori tv si devono attenere, non è di certo la Guida CEI 100-7 a fare titolo, ma bensì la Nordig Unified Requirements e tutti gli altri documenti a cui fa riferimento.
Per la sensibilità dei ricevitori le Requirements prevedono che un tuner DVB-T demoduli correttamente una QEF già a un livello di 30,6 dBuV (pertanto stai confermando che la Samsung è conforme alle Nordig):
Minimum signal level:
The demodulator operates on Gaussian channel at QEF performance (i.e. BER less than 2x10-4 after convolutional decoding and before Reed-Solomon decoding) with a minimum input signal of -78.2dBm across the whole UHF range (8k, 64 QAM mode, 2/3 code rate, Tg/Tu ¼, 8dB NF and 7.61MHz bandwidth).
Per il comportamento dei CAG ti avevo già risposto qui:
A monte di tutto bisogna assolutamente scremare i tv non compatibili al mpeg4 che o sono stati rottamati o decoderati, e pertanto bisogna focalizzarsi solo sul parco attivo dei tv T2 HEVC e dei residuali DVB-T mpeg4, questi ultimi in fase di uscita alla prossima introduzione del T2 (destinati anch'essi a rottamazione o a decoder esterno).
In conclusione non ci si aspetta dalla diagnostica di un IRD una precisione a livello strumentale, ma cè un'algoritmo da rispettare nella compilazione del firmware con delle specifiche tolleranze previste per i vari step di livello di segnale in ingresso e la SSI in percentuale deve dare una indicazione entro quei parametri.
Il livello di intervento del CAG non si può sapere a priori perchè nei tuner moderni interviene in modo multiplo e differenziale nei vari stadi di cui è composto il tuner stesso.
Alcune diagnostiche riportano anche il C/N oltre al valore di intervento del CAG e che ci siano differenze tra tuner di marca differente o tra tuner economici e pregiati è cosa ovvia.
Dopo tutta la disquisizione, a maggior ragione appare evidente che è consigliabile mantenere il segnale alla presa per una valore percentuale sotto il 100% (92-95% ritengo sia l'ottimale per i mux più robusti) in modo di apprezzare le differenze tra i segnali forti e quelli meno forti e riuscire ad avere anche una percezione dei fenomeni di fading sulla lettura della potenza invece che solo il repentino e improvviso calo di qualità con valori di potenza fissa al 100% perchè il CAG è in compressione.
