Ricevo uk spot a bologna ( parabola andrew 240 offset + quad invacom flangiato + feed channel master)
Da Appiano Gentile(co)con una 80cm motorizzata e clarke tech 3100 hd:Astra 2e e Astra 2f nessun problema su tutti i transporder(però se piove gli HD scompaiono).Con una 100 fissa e Clarke tech 2100 si guadagna circa 7/9% rispetto alla 80 cm. Test giorno sera(-4/5%) notte.
Ricezione 28.2E - Astra 2E
(aggiornato al 30-04-2014 h11:00 bobbys)
Marcomattxx -> Val di Susa -> 125 cm -> Astra 2E UK ok (10773H 13db SNR=85, 10788V 14db SNR=88, 10803H 14db SNR=89, 10818V 13db SNR=81)
mike71 -> Val di Susa -> 85 cm -> Astra 2E UK limite
ThePolo -> prov Torino -> 80 cm -> Astra 2E UK ok (L=65 Q=85)
gros55 -> Torino -> Selfsat H21D (70 cm) -> Astra 2E UK 0% (10743H Q=59, 10773H Q=57, 10787V Q=60, 10802H Q=58, 10817V Q=62,
10846V Q=0, 10862H Q=57, 10876V Q=62, 10920H Q=59, 10935V Q=0)
superdish66 -> prov Asti -> 125 cm (lnb Inverto Black Ultra) -> Astra 2E UK ok
Papu -> Cuneo -> 100 cm -> Astra 2E UK ok (10758V 58%)
batch -> sud Piemonte -> 80 cm -> Astra 2E UK ok (10818V ok, 10773 H squadretta)
leite -> sud Piemonte -> 80 cm -> Astra 2E UK 0% (10773H 6,2db, 10788V 8db 50%, 10803H 6,9db 43%, 10818V 8,7db 54%, 10847V 0%)
Maxicono -> Novara -> 90 cm -> Astra 2E UK ok (10773H SNR=41, 10818V SNR=41)
Maxicono -> Novara -> 125 cm -> Astra 2E UK ok
Furybody -> San Remo (IM) -> 85 cm -> Astra 2E UK ok (24-20 ok L=54) (20-24 ko)
luky007 -> prov Genova -> Channel Master 120 cm (lnb nvacom c120 Quad) -> Astra 2E UK ok (10847V L=87 Q=59)
BRYCE -> Cogoleto (GE) -> gregoriana 90 cm (lnb invacom quad) -> Astra 2E UK ok (L=50)
piazzolla -> Genova -> Visiosat Big Bisat multifeed 91x70 cm -> Astra 2E UK 0%
ettore88 -> Rapallo (GE) -> 105 cm (lnb Inverto Black Ultra) -> Astra 2E UK ok (10714H L=87 Q=67, 10729V L=87 Q=67, 10744H L=87 Q=67, 10758V L=87 Q=68, 10773V L=88 Q=66, 10788V L=88 Q=67, 10803H L=88 Q=66, 10818V L=89 Q=69, 10832H L=88 Q=66, 10847V L=88 Q=66, 10862H L=87 Q=64, 10876V L=88 Q=68, 10891H L=88 Q=66, 10906V L=88 Q=69, 10921H L=88 Q=67, 10936V L=88 Q=68)
crazyuby -> Varese -> 240 cm -> Astra 2E UK ok (10744H 8,9dB, 10773H 9,5dB, 10788V 11,1dB, 10802H 10,2dB, 10818V 10,9dB, 10847V 10,3dB, 10864H 10dB, 10877V 10,4dB, 10921H 9,3dB, 10936V 11dB)
hosso -> Como -> 90 cm -> Astra 2E UK 0%
glskm -> Appiano Gentile (CO) -> 100 cm -> Astra 2E UK ok (sera -4/5%)
glskm -> Appiano Gentile (CO) -> 80 cm -> Astra 2E UK ok (con pioggia 0%)
t.mac -> Vigevano (PV) -> 125 cm -> Astra 2E UK ok (10847V Q=68, 10773H Q=77, 10788V Q=72, 10803H Q=79, 10818V Q=70, 10877V Q=72)
gianluk -> Magenta (MI) -> 150 cm -> Astra 2E UK ok (77dB, margine 5.5dB, BER=1e-5)
gianluk -> Magenta (MI) -> 120 cm -> Astra 2E UK ok (10dB)
bobbys -> prov Milano -> 90 cm -> Astra 2E UK ok (6-19 ok) (19-6 ko) (10773 H L=55 Q=45, 10788V L=60 Q=45, 10803H L=60 Q=45, 10818V L=60 Q=50, 10877V L=55 Q=45)
spinner -> Milano -> 120 cm -> Astra 2E UK ok
Alistair -> Milano -> 100 cm (lnb Inverto Black twin) -> Astra 2E UK 0%/limite
S7efano -> Milano sud -> 80 cm -> Astra 2E UK ok (10744H ok, 10773H ok, 10788V ok, 10803H ok, 10818V ok Q=64, 10847V ok, 10862H ok, 10876V ok, 10921V ok, 10936V ok) (Q=54-60%) (sera/pioggia -6%)
pierangelo74 -> Lodi -> 125 cm -> Astra 2E UK ok (10847V Q=68, 10773H Q=77, 10788V Q=72, 10803H Q=79, 10818V Q=70, 10877V Q=72)
antoniopev -> sud Lodi -> 150 cm -> Astra 2E UK ok (10788V 10.9dB, 10818V 7.9 dB, 10847V 7.5dB, 10877V 8.7dB, 10936V 11.1dB)
julienr18 -> Piacenza -> 85 cm -> Astra 2E UK ok/limite
siricomarco -> prov Lecco -> 80 cm -> Astra 2E UK 0%/limite
thepictors2 -> nord Bergamo -> 100 cm -> Astra 2E UK ok giorno (L=80 Q=50) (sera 0%)
stascar -> prov Mantova -> 100 cm -> Astra 2E UK 0%/limite
Digitalbi -> prov Verona -> 180 cm -> Astra 2E UK ok (6-19 ok) (19-6 ko) (10788V ok, 10802H ok, 10817V ok, 10847V ok, 10861H ok, 10920 H ok, 10935 V ok)
mattme -> Cerea (VR) -> pellini pf 150 cm (lnb Inverto Black Ultra) -> Astra 2E UK ok (L=90-60 Q=80-38)
nzwarrior -> prov Padova -> 100 cm -> Astra 2E UK 0%
massimomarcello -> prov Rovigo -> 125 cm -> Astra 2E UK 0%
DTTFANS -> Taglio di Po (RO) -> 110 cm -> Astra 2E UK 0%
bok -> Taglio di Po (RO) -> 305 cm -> Astra 2E UK ok (L=92 Q=63) (sera Q=56)
Ryo Saeba -> Treviso -> 90 cm -> Astra 2E UK 0%
pitussat -> Belluno -> Prodelin 180 cm -> Astra 2E UK ok (Q=53/61)
Another -> prov Trieste -> 125 cm (lnb Inverto Black Ultra) -> Astra 2E UK 0%
danmich -> Modena -> 310 cm -> Astra 2E UK 0%
gosier07 -> sud Modena -> 180 cm -> Astra 2E UK 0% (L=43)
teletecnica -> Bologna -> andrew 240 cm offset + quad invacom flangiato + feed channel master -> Astra 2E UK ok
Luxlizard -> Bologna -> 150 cm -> Astra 2E UK 0% (2.30-3.30, 9.30-13.30 BBC ok)
PantaSat -> Toscana (PT) -> 150 cm -> Astra 2E UK 0%
elettriko -> Firenze -> 250 cm -> Astra 2E UK ok (10773H ore 9 MER=0,1db SNR=0,6db Q=65, ore 12 MER=9,2db SNR=1,7db Q=70)
elettriko -> Firenze -> 180 cm -> Astra 2E UK 0%
torresialberto -> prov Macerata -> 150 cm (lnb 0.2 dB) -> Astra 2E UK 0%
Foxbat -> Roma -> Channel Master 120cm -> Astra 2E UK 0%
willy067 -> Roma -> 120 cm -> (lnb Inverto Black Ultra quad) -> Astra 2E UK 0%
allievo266 -> Guidonia -> -> 150 cm (lnb Inverto Black Ultra quad) -> Astra 2E UK 0%
stilo -> Abruzzo -> 300 cm -> Astra 2E UK ok (10-17 ok) (17-10 ko) (10788V 6.5dB, 10803H 6.5dB, 10847V 0%, 10936V 0%)
-Mirco- -> prov Caserta -> 125 cm -> Astra 2E UK 0%
Capitan_Uncino -> prov Napoli -> 150 cm (lnb Inverto Black Ultra) -> Astra 2E UK 0%
giannimaresi -> Napoli -> 120 cm (lnb Inverto Black Ultra) -> Astra 2E UK 0%
korchm48 -> Potenza -> Prodelin Prime focus 340 cm (lnb invacom quad) -> Astra 2E UK ok (10714H 7.5dB, 10729V 6.5dB, 10744H 7.6dB, 10758V 6.7dB, 10773H 7.7dB, 10788V 6.5 dB, 10803H 7.8dB, 10818V 6.9dB, 10832H 7.7dB, 10847V 6.9dB, 10862H 7.4dB, 10876V 7.3 dB, 10819H 8.0dB, 10906V 7.5dB, 10921H 8.2dB, 10936V 7.2dB)(h14.15 25-04-14) (min. h17.30 -0.7dB)
MEGADISH -> Sicilia -> 300 cm -> Astra 2E UK 0% (canali sintonizzati)
Altre segnalazioni da altri forum:
Peter -> Pinerolo (TO) -> 100 cm -> Astra 2E UK ok
Martina -> Torino -> 100 cm -> Astra 2E UK ok
Mad Dog -> Genova -> 100 cm -> (lnb inverto) -> Astra 2E UK ok
derek -> Taino (VA) -> 100 cm -> Astra 2E UK ok (L=75-80 Q=100 Humax) (Crazyscan 2E 11,4-13,9dB, 2F 10,7-13,6dB) (con pioggia -1/1.5dB)
? -> Trezzo sull'Adda (BG) -> 100 cm (lnb Inverto Black Ultra) -> Astra 2E UK ok
SSDouble -> Parma -> 150 cm (lnb Inverto Black Ultra) -> Astra 2E UK ok
Nick G -> La Spezia -> 150 cm -> Astra 2E UK (giorno ok) (sera ko)
SamD -> La Spezia -> 100 cm -> Astra 2E UK (giorno squadretta) (19-6 ko)
denis1501 -> Lazio -> 125 cm (lnb Inverto Black Ultra quad) -> Astra 2E UK 0%, Astra 2E PE ok, Astra 2F UK 0%, Astra 2F PE ok, Astra 2A NE 0%, Astra 2A SE ok
etabeta -> Napoli -> Irte 400 cm -> Astra 2E UK ok
Markw -> San Marcello (AN) -> 120 cm -> Astra 2E UK 0%
totbros -> Ungheria -> 400 cm -> Astra 2E UK (10773H 39%, 10788V 45%, 10803H 40%, 10818V 46%, 10847V 48%)
